RuSsMaN
Pudknocker
Black Sand Cable Arctic Blue MK II Power Cord Review/Info
*PLEASE POST ONLY REVIEWS FOR THIS PARTICULAR CABLE IN THIS THREAD*
www.blacksandcable.com
$149 4-6 ft
Terminated with Ultra High quality 15A Hospital Grade Male Plug and Hospital Grade 15A IEC Connector.
(Furutech FI-25 IEC & Male available as an upgrade - $150.00USD per cord)
12 AWG 3 (99.9%)conductor twisted pair internal wire alignment that has been treated to prevent corrosion and oxidization
Entire assembly is EMF & RF shielded
Copper annealing process that produces a crystalline structure that has current flow unidirectionally
Stranded core
Each conductor is Teflon shielded
Wound dielectric
Audio grade outer jacket
New braiding technique that creates an active level of shielding
UL listed and CSA certified
Temperature range: -40ø C to +90ø C
Voltage rating: 300 volts
Max. Amps @ 120V: 30
All terminations, IEC and male end are treated with CAIG Pro Gold prior to final assembly
Final cord is bench tested and burned in before it goes out the door!
$149 4-6 ft
Stranded core
Wound dielectric
