SiliconTi
Super Member
Well, I finally bit the bullet on the Tobin mods for my 302s. I had high hopes. I performed the mods even taking the time to tuck it all into the original cans so it looks stock at first glance. I checked everything 10 times before buttoning them up.
Ran some test listening - disappointed. The highs are way too muted. This may make them "balanced", but the tweeters are too "cold" now. Bass and mid are much cleaner.
If I did it again, I think I'd recap and add L-pads to the tweeters to better control them (they were very "hot" before the mod).
I hate to rip it all out, but now I need the EQ at 10K bumped a bit to make them sound right (to me). I dunno, maybe I'll create my own crossover for them.
Dang it.
EDIT:
OK, if you are looking for info on the Tobin mod, here is a summary of what over a year of trial, error, blood, sweat, and tears has resulted in. Feel free to look through the entire thread:
The Tobin mod does work.
Using an L-pad to attenuate the tweeters is a better (more flexible) option than the 7.5 Ohm resister.
Setting the Woofer to the end of the inductor, (the lug marked N-101 on my crossovers) and the mid should be connected to the center tap of the inductor (the lug marked N-102 on my crossovers).
Retrovert's flower-pot midrange backer is a great addition while you are in there.
PAY ATTENTION TO DETAIL: make sure it is all correct before you judge.
The amplifier used may make a difference as well, keep that in mind.
Dang it.
EDIT:
