I have a pair of Bogen MO100A's that I want to restore, one of which (the one pictured here) is supposed to be unmodified. I have all the necessary tubes as well as the test gear shown below (am I missing anything? ). The first question I have concerns the use of the DBT. Do I need to have all the tubes in place before testing for shorts with the DBT, and for how long. The Amp draws 250 watts and the bulb is rated at 250 W also. The tubes are expensive and somewhat hard to come by and I would rather not blow them up if at all possible.
The second question is: Assuming the DBT test is successful, for how long and at what rate of increase should I use the Variac?
One thing of note though is that this unit had been subjected to the usual highly scientific test used by most ebay sellers prior to my purchasing it; i.e.: I plugged it in and it lit up, therefore it is in working condition.
Note the resistor with a lovely blob of solder on it. It is labeled 510 ohms, 5%, 7Watts. Could someone tell me what kind of a resistor this is as it will definitely need to be replaced. I am assuming some form of ceramic resistor.
Any and all help is much appreciated.
