Bought a Mustang this weekend
Discussion in 'Wheels, Wings, Mud, and Water' started by cratz2, Feb 5, 2018.
  1. cratz2
    cratz2 Addicted Member
    5,618
    Indy, IN
    So, I bought a 1993 Mustang this weekend. It's a lowly 4-cylinder, 5-speed manual but it's in fantastic condition. 63,000 miles. Technically a four owner car, but the person th an owned it from 1995 through 2008, bought it back in 2010.
    One mechanic maintained it since 1995. Paint looks good. No rust anywhere including the towers. It needs some new weather stripping and a good polish and wax. The color wouldn't have been my first choice, but it will grow on me.
    We have a Mustang/Ford guy in the family that used to build race engines and probably next year (possibly this year) we will end up doing a swap with a slightly built V8 that he has. It's perfectly driveable right now and I'll start driving it a day or two each week just to get some miles on it.
    This morning, it was eight degrees outside and it fired right up on the first crank.
  2. Hajidub
    Hajidub Chihuahua/Pug = Chug Subscriber
    5,629
    Colorado Springs, CO
    She's a beaut! I honestly had no idea they made them in 4-bangers back then!
    cratz2 likes this.
  3. damacman
    9,163
    Gilbert, AZ
    Looks sharp with the 10-hole wheels. You could put GT emblems on it, hang a fake pipe out the rear on the passenger side, put LETS GO on the license plate and then blow off anyone that asks to race . . .
    cratz2 likes this.
  4. MaxxVolume
    MaxxVolume Addicted Member
    5,313
    And not just garden-variety 4-bangers, either.... Ford`s skunkworks (Special Vehicle Operations, or "SVO") had a high-performance version, turbo`d, heavy-duty suspension and brakes, lots of nice cosmetic bits, too. Friend of mine had one with a 175 shot of nitrous, it would run 12s on the juice (!) (broke a couple of transmissions with it, though).
    Mike Sweeney, cratz2 and HunterMcD like this.
  5. HunterMcD
    HunterMcD Everything louder than everyone else Subscriber
    772
    Flint, MI
    Before you go throwing in a v8 look into the turbo 4 cly engines. Same 2.3 as the one you have now but a slightly different head. They’re a direct bolt in. I built one for my wife’s 88 convertible. Thing is crazy fast with upgrades and still gets close to 30mpg. There’s guys out there running 9s on slicks and driving them to work daily.
    electronjohn, cratz2 and C6Bill like this.
  6. Hajidub
    5,629
    Same motor used in the Escort Cosworths. I understand Maxx's post but the OP's car is almost mid-90's.
    cratz2 likes this.
  7. HunterMcD
    772
    Flint, MI
    The engine I used was from an 88 turbo coupe (thunderbird). It would bolt right in. You can’t even tell the 2 apart if the turbo was removed from the side. I also used the ecm. All the accessories swap directly over too. Even if it’s a 90s car.
    Grenadeslio, cratz2 and beat_truck like this.
  8. gadget73
    37,829
    Southern NJ
    which came directly from the 1982 Lincoln Continental. Its the only reason I can get the rear caliper bushings for my 84 Conti and axle shafts for it and my Mark VII. The SVO used those parts, which are not the same as standard Mustang ones.
    cratz2, MaxxVolume and HunterMcD like this.
  9. MaxxVolume
    5,313
    The SVOs also had 5-lug wheels (with beefier axles).
    cratz2 likes this.
  10. damacman
    9,163
    Gilbert, AZ
    And nobody can ever explain why ... talk of greater torque than the 302 from a dig snapping wheel studs was always nonsense ... maybe, just maybe, the suspension was refined just enough to snap wheel studs when cornering hard.
    cratz2 likes this.
  11. cratz2
    5,618
    Indy, IN
    Yeah, a buddy used to have a (I think) 1986 SVO and a Merkur XR4Ti. And a couple Thunderbird Turbocoupes.
    Plenty of Mustangs had 4-cylinder engines. My ex-wife had a 1980 Mercury Capri with a 4-cylinder, 4-speed and I had a 1979 Mustang pacecar which originally had either a turbo 4 or a V8. Mine had a replacement naturally aspirated 2.3L 4-cylinder but was originally a turbo car.
    I'll almost certainly end up going with a V8. This guy literally has multiple engines on engine racks. The one I'll most likely end up with is a 425-450 dyno'd HP (not BS numbers) roller 347. I will get it for a very good price. Alas, it will not get 30 MPG. Not even going downhill with a strong tailwind.
    Aesthetically, I really like the Cobra turbine type wheels. I won't spend a fortune on them, but if I can find a set for $500 or less, I'll nab them.
  12. slow_jazz
    slow_jazz AK Subscriber Subscriber
    13,889
    SE Michigan, Downriver....
    Congrats.
    I own 2 Mustangs right now.
    cratz2 likes this.
  13. olson_jr
    olson_jr Dave? Dave's not here man. Subscriber
    14,373
    Pilgrim Hills Michigan
    The first car I worked on at FoMoCo was the 1990 2.3L Mustang. The 91~ 93 Dual Plug cars were a big improvement in driveability. 1993 was the last year for that body style and for the "lowly" 2.3L SOHC Dual Plug Engine. Eight spark plugs, eight ignition wires, dual coil packs. We used to joke, "The same tune up cost as a V-8, but with half the power!"
    If your car is like most of the 2.3L MT Mustangs I have driven you can get the hatchback glass to resonate like a giant speaker. Smooth road, second or third gear, light steady throttle, somewhere between 1000 & 1300 RPM the glass will begin to resonate, and if you are good, you can vary the frequency and make the car sing to you.
    We spent some long, dark hours in Bemidji MN working on the cold weather engine calibrations, so it is good to hear this one still starts on the first crank at 8 degrees.
    cratz2 likes this.
  14. gadget73
    37,829
    Southern NJ
    yep, also Continental parts. Axles weren't actually any beefier but its longer than the standard Fox chassis axle. 5x4.5" bolt pattern, same as the full size cars. Other Mustangs of the time had 4 lug wheels with weenie rear drums vs the SVO/Continental/Mark VII's four wheel disc. The Lincolns got a 5 lug wheel and the better brakes probably just for weight reasons. Despite the extra weight on the Lincolns they stop very well. I imagine the SVO's lower weight would stop on a dime and give change.
    I doubt the 5 lugs had anything to do with studs snapping and more to do with the brakes. It made more sense to simply grab parts that already existed vs special-engineering a 4 lug rear disc brake.
    have to agree about the twin plug 2.3 working well. I've driven Rangers with that motor and they definitely had more zip than the standard 2.3
    stish, olson_jr and cratz2 like this.
  15. leesonic
    leesonic Hold on, here comes the bass. Subscriber
    4,691
    Southern NJ
    No, it's not. The Escort and Sierra Cosworths used a 2 liter "Pinto" motor with a 16-valve DOHC head designed and made by Cosworth engineering. The Mustang SVO, Turbocoupe, and Merkur XR4Ti used a 2.3 liter "Lima" motor with an 8-valve SOHC head.
    Lee.
    HunterMcD, cratz2 and olson_jr like this.
  16. cratz2
    5,618
    Indy, IN
    There are a couple guys at my work with Rangers and the 8-plug 4-cylinder engines. One guy has one with 700,000 miles on it and the transmission has been rebuilt twice but he says the engine has never been apart. Another guy has somewhere in the high 200,000 mile range and has had it since about 30,000 and swears other than a couple sensors and some front suspension work, he's never had to do anything to it.
  17. Hajidub
    5,629
    Yeah you're right! There's a nice handful of cars that used the 2.3 T back in the day...wow.
    cratz2 likes this.
  18. Shadowdog
    Shadowdog Super Member
    2,999
    Flin Flon, Manitoba
    Nice car!
    For the stroker 302 the 3.25 crank 331CI version would be my choice do to the rod ratio (less thrust on the cylinder walls) plus more rev capability like the 302 & smoother! 347 has 3.40 stroke crank so will affect engine life more negatively.
    cratz2 likes this.
  19. cratz2
    5,618
    Indy, IN
    I hear ya. I won't be building it,just getting a great deal on an already built engine that only has maybe 2,000 miles on it.
    I'd probably go with something revvy and has a lumpy idle for auditory pleasure.
    I've been around fast cars my whole life, but I'll mostly probably just lean into it every once in a while. I'll leave the stop light antics to the youngsters.
    MaxxVolume likes this.
  20. grillebilly
    grillebilly Empty Head Subscriber
    16,618
    Fairfax VA
    Nice looking ride. I would just drive it as is. Probably an excellent commuter vehicle with a little sporty look.
    I'm guessing the 4 cyl cars came with rather wimpy rears and gearboxes. So plan on fixing them when the V8 splatters 'em.
    stish, nj pheonix and cratz2 like this.
