Brand new factory Infinity Monitor II Walsh Tweeters
Discussion in 'Infinity Loudspeakers' started by Beaglemaster, Mar 27, 2018.
  1. Beaglemaster
    Beaglemaster New Member
    49
    NYC-Staten Island
    Not too long ago I was lucky enough to purchase two brand new, never used, Infinity Monitor II Walsh Tweeters in original factory Infinity shipping boxes, from a reputable eBay seller. Both tweeters are stamped 902-0033 on the bottom magnets and work fine. To my ears, both have approximately the same loudness level. However, one tweeter is clearly brighter than the other. I'd estimate a noticeable 4 to 5db brighter. I tested them on their own with the proper resistors, side by side, within inches of one another. I switched cables, used different amps, reversed left and right outputs, switched speakers, made sure to use a mono source, etc. and the excessive brightness always remains with that particular tweeter. There's no distortion in it, just a boosted treble.
    I'd assume they should sound pretty much the same, so this is a bit disappointing. Does anyone have any insight as to what might be the reason for the noticeable difference in treble between the two tweeters? Is there a workaround to the problem that anyone could recommend?
  2. chef free
    chef free AK Subscriber Subscriber
    2,285
    Hayward, Ca
    The tweeter is filled with foam. Foam degrades with time no matter how it's stored. It's possible that the interior foam has degraded differently in the two tweeters.
  3. Beaglemaster
    49
    NYC-Staten Island
    That sounds reasonable. However, from what I can see, the foam in both look about the same. Neither shows signs of degradation. I bought them as backups in case one (or both) of the Walsh tweeters in my IIA's conks out in the future. The foam of the new replacement pair looks even better than the foam in my still working original tweeters. Thanks!
  4. swechsler
    swechsler Frog Whisperer
    5,304
    7th row center
    I don't have any Walsh tweeters, but is there any chance that some foam crumbs got into the voice coil gap?
  5. Beaglemaster
    49
    NYC-Staten Island
    I guess anything's possible. I'll look into that in case I absolutely must take them apart.
    I'm not looking forward to doing that. lol
    Thanks!
  6. chef free
    2,285
    Hayward, Ca
    Have you compared the other two Walsh tweeters to the "new" ones?
  7. idadude
    idadude AK Subscriber Subscriber
    961
    Meridian, Idaho USA
    Is there a possibility of a bad solder joint like on the QLS tweeters? I'm not sure how the Walsh are put together, so it may or may not be a possibility. Have you checked the ohm readings on both tweeters? I just got a pair of 409-125 tweeters today and they read 3.3 & 3.4 ohms. Sound great in my RS 2.5's.
    Larry D.
  8. tubed
    tubed Lunatic Member
    15,858
    Aztlan
    As Larry mentioned his tweeters measured slightly different from one another.
    Perhaps the OP might get a greater difference by measuring?
  9. Beaglemaster
    49
    NYC-Staten Island
    Yes, all sound pretty much the same except for the one that's a bit bright.
  10. Beaglemaster
    49
    NYC-Staten Island
    As of now I don't have a meter. Just doing it by ear, so far.
  11. Jimbo40
    Jimbo40 Active Member
    106
    That original was 906-0060 you really should barely hear them except for tones over 10k why don't you try to subdue it with a little more poly. I have done so much experimenting with voice coils to get the same sound.
    I bought 2 off ebay working. they were receive with cones smashed and one was off. trying to fine gold cone material and a super high freq voice coil. if you had the right voice coil there easy to repair.
  12. Beaglemaster
    49
    NYC-Staten Island
    You said the originals were stamped 906-0060. I don't know what my originals are stamped because they're both still working and mounted in the IIA speaker enclosures. The ones I just purchased on eBay are stamped 902-0033. They were never used and packed in original Infinity boxes. They look exactly the same as the pair in my speakers except for the color. The one's I purchased on eBay are bright gold cones. They're approximately the shade of a beautiful gold coin. The ones in my speakers are a more subdued "goldish" tone. In 1974, before I owned the IIA's, I purchased the original Infinity Monitors and those cones were SILVER, not gold or "goldish". So that's three different shades I've seen so far. Would there be any other differences between the 906-0060 and 902-0033 series?
    Regardless, concerning the replacement pair I just purchased, one tweeter is still brighter than the other. To make matters worse, my technical skills are limited and I'm afraid to mess with them. lol
    I'm hoping that if I ever have to install them, maybe just turning back the rear mounted tweeter control on ONE of the speakers would balance them and make them sound the same?
    Thanks!
  13. tubed
    15,858
    Aztlan
    Never heard of the 902-0033 Walsh tweeter, only the 902-
    0060.
    Since there seems to be a 902-0066 Walsh, there is no reason to think that they would not sound "different"from the originals:dunno:
  14. Beaglemaster
    49
    NYC-Staten Island
    Photo of the Walsh tweeter stamped 902-0033 on bottom magnet.
  15. Beaglemaster
    49
    NYC-Staten Island
    From the original eBay ad quoted below..........
    INFINITY ICE CREAM CONE TWEETERS 902-0033 NEW OLD STOCK
    THESE TWEETERS WERE PURCHASED FROM INFINITY, AS YOU SEE THEM , FOR A REPLACEMENT BUT WERE NEVER USED.
    THE FOAM IS IN GOOD CONDITION , THE GOLD CONES HAVE SOME DENTS ( SEE PHOTOS ) BUT THIS DOES NOT AFFECT FUNCTION .
    AS YOU CAN SEE THEY HAVE AN ADDITIONAL MOUNTING RING THAT COMES WITH THEM FOR MOUNTING IN DIFFERENT SPEAKERS.
    WARNING THESE ARE VERY DELICATE TWEETERS AND NEED TO BE INSTALLED BY A PROFESSIONAL !!!!! SOME MODIFICATION MAY BE NEEDED !!!!!
    PLEASE VIEW ALL PHOTOS THESE ARE THE ONLY NOS REPLACEMENTS FROM INFINITY AND ARE NO LONGER AVAILABLE .
    SOLD AS A PAIR . FOR THESE SPEAKERS :
    WTLC - Wave Transmission Line Column
    2000 AXT
    2000 II
    MONITOR
    MONITOR IIA
  16. Beaglemaster
    49
    NYC-Staten Island
  17. Beaglemaster
    49
    NYC-Staten Island
    Both tweeters read the same, but still, one's brighter than the other.
  18. idadude
    961
    Meridian, Idaho USA
    Well, since we are not seeing an electrical difference there must be a mechanical or construction difference. I wonder if these are ferrofluid damped and maybe one has no ferrofluid and the other does. Beyond that I have no other ideas of why they should sound different.
    Larry D.
  19. slimpikkins
    slimpikkins Super Member
    1,809
    South East PA
    Hey Beaglemaster, my bet is if you placed them in the circuit of the speakers they would sound the same. They are very rare for sure, nice looking pair, maybe the nicest anywhere. Good luck.
    Jim
  20. Beaglemaster
    49
    NYC-Staten Island
    That's good news! Since my originals still work, I only tested them coming from the the L-R outputs from my amp with the proper resisistors. They test fine and sound smooth, but there's just that noticeable difference in treble.
    I'm not arguing, but just curious as to why placing them in the circuit of the actual speakers would make them sound the same? Since I'm not very "tech savvy", I'm trying to learn what's going on.
    Thanks Jim!
    pauljh likes this.
