TellMeWhy
Dear Friends,
Today I was lucky enough to acquire a pair of Braun LV1020 active speakers- huge, impressive beasts from the early 70's with internal tri-amping. They cost a fortune in their day, and seem to be in original and very clean condition inside and out.
But the sound is way of what you would I expect, which I am assuming is probably down to 45 year old electronics. I have done the usual clean up and deoxit, but it didn't effect any change. I have also checked and changed connection cables.
One speaker has a constant buzzing (mostly on the tweeter channel), even with no source plugged in, which I suspect is probably down to a bad transistor (BC157a), but I am no electronics ace, and it could be a bad cap or loose joint.
So my question is- is it worth giving the amps to my tech to recap and over hall them? The boards are easy to remove and to work on, but hard to test (without being plugged into the speaker units). I guess that would end up being quite an expensive operation.
Or do I get an active crossover, buy 3 new amps and use them like that?
Or do I try and find a similar used Braun or ADS crossover and see how that works?
What would you guys do- they are quite a stunning pair of speakers....
Nice evening,
Jon
Nice evening,
Jon
