I am updating my Scott 222c, mainly the bias/12AX7 supply. First thing, the selenium rectifier was failing, so updating to a modern bridge and adjusting the resistor is a no brainer. However, I have read that using much higher rated rectifiers with a small load will distort their outputs.
Basically, I have a nice 25A/400V chassis mount bridge that fits perfectly into where the old selenium was, but I don't want to use it if the experienced persons on here would indicate that it is too much to the point that it won't operate correctly due to the minimal load of the filiments and bias requirements <1A.
I also have a 1.5A/300v bridge that I could use, so which would be better for the application?
Thanks
Thanks
