Broken selector switch shaft fix
Discussion in 'Marantz Audio' started by wlhd1610, Feb 24, 2016.
  1. wlhd1610
    wlhd1610 Penny and her new friend Subscriber
    2,268
    upstate new york
    Tom (catrafter) was kind enough to show me this procedure years ago when I was about to attempt to change out an entire 5 wafer selector switch.
    Rather then try to unsolder 50 connections - a herculean task to undertake - he said to just swap out the shaft itself!
    Here's what we all dread!
    The business end...
    The donor switch....
    Broken switch pulled out in preparation.
    Remove the two nuts and lockwashers from the back of the switch but do not pull out the shaft just yet....
    Carefully remove both nuts from the ends of the long screws on the donor and pull the front shaft out making sure that the donor switch shaft is turned to the EXACT SAME position as the broken switch.
    This will insure that it slides right into the existing switch wafers....
    You have to carefully pull the broken shaft out with one hand while your other hand keeps a small amount of "clamping force" holding the front and back wafers together.
    Doing that will keep all the spacers between each wafer from falling out and you do NOT want that to happen!
    Since you previously made sure that both switch shafts were in the same detented position you can carefully and slowly insert the new shaft assembly while watching that all the spacers line up.
    When fully inserted go ahead and install the end nuts with lockwashers.
    I was extremely nervous the first time but as I did more of them I became more comfortable.
    It is an extreme time saver vs. changing out the entire switch assembly.
    ( Sorry - I couldn't take a pic of the existing switch with the shaft pulled out without letting all the spacers falling out! )
    Here's the old switch shaft...[​IMG]
    Thanks Tom for a great time saving tip!!
    Bob
    KutzlerTrans, Rasputin47 and quadtech like this.
  2. KutzlerTrans
    KutzlerTrans Jennie & I with Buddy and Barney. Subscriber
    2,998
    Wisconsin
    I didn't believe it until i saw it. Thanks for the post.
  3. rBuckner
    rBuckner Luv 2 Restore Subscriber
    9,575
    Prescott, Arizona
    I dread the day I have to do this. But it's probably like going to the doctor or dentist, the thought of it is worse than the actuality! Thanks for the helpful post Bob.
    Switchblade likes this.
  4. Bogeydeuce
    Bogeydeuce AK Subscriber Subscriber
    30
    SW North Dakota
    Would wrapping wide tape, such as duct tape, around the wafers before removing the shaft help hold it in place?
  5. wlhd1610
    2,268
    upstate new york
    You really need to see that the two long screws are going through each wafer and it's associated spacer as you insert them.
    If they get slightly out of place then you stop and move them so it goes smoothly.
    It's really heart stopping as you do it but the sense of immense satisfaction after its done makes it well worth it!
    Bob
  6. callahan1973
    callahan1973 AK Subscriber Subscriber
    17
    I'm curious - I have an extra switch laying around from a 2220b that has 4 positions and I need to replace a switch that has 5 positions. There is no way I can use the shaft out of the 4 position to go in the 5 position switch on my receiver, right?
  7. catrafter
    6,063
    Montana
  8. tbone8
    tbone8 Active Member
    144
    Wow, glad I found this thread. I had a Dolby switch that was broken and was dreading trying to solder a million tight connections in. I was worried about the little spacers so I came up with inserting a cotton swab handle to chase the screw. Worked like a champ though getting the nut back on the far side screw was a technical maneuver. Hope this mod helps!
    quadtech likes this.
  9. Steven Tate
    2,632
    N. Richland Hills, TX
    This is a great addition to the procedure. I'm going to be trying this soon. I'm thinking of trying to put a tiny drop of super glue at each joint between a wafer and the tubing spacers before removing the screws that hold it all together - just enough for capillary action to suck the glue under the spacer, but not enough to grab the screw. I'm going to try this with a spare on the bench before I try it in the unit. But I think the wooden sticks will be an additional aid in holding it all together.:thumbsup:
  10. tbone8
    144
    I thought of trying the super glue but the sticks were the perfect size. Just use the stick to push the screw out and you are golden. Good luck!
  11. Dearslayer
    Dearslayer AK Subscriber Subscriber
    814
    Ontario Canada
    I have a 2230 with a broken selector shaft and when I got this unit from a friend he also gave me what he said was a replacement from another 2230 that he had intentions of having a tech replace for him but never did get around to it. I believe it's may be the same but there are some differences mainly the fact that the original in the unit now doesn't have nuts onto the ends of the threaded shafts. Seems the threaded shafts are screwed into the threaded holes in the rear retaining plate whereby the replacement does have nuts securing things in place. I'm concerned that if I do manage to remove the existing broken shaft that the replacement may not be exactly the same. I guess no way to be 100% certain other than visual??Also I'm wondering if the front end has to be removed or loosened to allow enough room to remove the old switch. Currently its extremely tight with not much room to even access the far screw at all.
  12. tbone8
    144
    The shaft looks the same size and length so it should be good hopefully. If you can get it out enough to take it apart and slide some cotton swab sticks like I did, it will make it much easier to replace the shaft.
  13. Dearslayer
    814
    Ontario Canada
    The problem is that where the switch sits in the picture is basically where it is and will go no further and that's with the wire retainer unfolded to release as much wire as possible. That's why I'm thinking something has to be let go on the front face even a little to allow that switch some more room to come free to access that back screw.
