I need a good adjustable bench power supply to build/diagnose tube electronics. Commercial supplies are way too expensive. Heathkit type models don't source enough B+ current. I decided I'm going to attempt to design and build my own.
An older thread here discusses the design (no need to read it unless you are morbidly curious or want to see the schematic). The summary of that whole thread is: I started out thinking I was going to build a fully tubed regulated supply, but then later last year after a few determined forum members convinced me of my errant ways, I changed over to a full solid state design based on Michael Maida's approach. I've spent the last 3 to 4 months working out the design details.
A good chassis with a 5" or 6" high front panel is hard to find. (Shorter front panels won't work--not enough real estate.) The only two manufacturers I could find that do quality work were Landfall Systems and Par Metal.
I decided to go with Par Metal. Now, after a long winter's nap waiting for it to be delivered, I can finally start the assembly. It's a nice chassis, with really nice front handles, a very hefty gauge front panel, and a super thick bottom plate that can hold the weight of heavy transformers:
First things first though. I need to figure out where all the stuff goes on the front panel. Here's how I think it will be laid out (purple rectangles are the digital meters):
I'm not sure how I will get the lettering on. A proper job would have it silk screened or laser etched maybe. A trophy shop might be able to do it. Front Panel Express might also be able to do it.
I'm treading into uncharted waters with this build, and I suppose there's still a chance it could all go belly-up, but...I'm going to try anyway.
