swechsler
Frog Whisperer
The subwoofer in question is an NHT SW10 Mk II. All the sub will do is produce a loud hum when the gain knob on the back is turned all the way clockwise. I pulled the amp and looked for obvious issues (leaky caps, broken boards) and didn't any. The sub is connected to an HT receiver with a sub out, so I really don't need any of the controls on the sub's amp. I have several unused power amps sitting on shelves in my storage area, so I'm thinking I could wire one of them in using the NHT's high level inputs, and inside the cabinet, wire the input directly to the driver. I prefer this idea since it doesn't require modifications to the cabinet, and if at some later date I find a replacement amp (or decide to get this one repaired) I can get it back to stock appearance fairly easily.
I know that plate amps are available, but I suspect using any of them would require making severe changes to the cabinet. I could also get the amp repaired, but it looks like repair costs would approach the working value of the sub. In addition, budget is tight right now; my entire team at work has been laid off in favor of cheaper offshore workers (in Warsaw, of all places).
The amps I'm thinking of using are commercial amps from Crown, QSC or Rane. Any caveats? Any reason not to do this?
