Thatch_Ear
Addicted Member
I bought a spool of old WE tinned and insulated solid 26AWG copper not long a goe and decided to buid a pair for my mains. Same wire and insulation type (celoneyse) but this wire is a bit thinner. cut to lenghths of just over 9'ea 24 of them. The Pos and Neg of each cable has 6 lenghths braided so that they all crossover many times, Not a easy task keeping a dozon wires over 9' long in order so the the braids are proper. It took about 6 hours or so to do it.
I took the short legth of 16 per brade out and installed these. I noticed an immediate improvenent and I think that is do to the fact that I could attach these directly to the Binding Posts in the amp and the speakers, leaving out the RS Banana plugs,
The same type wire is hooked to the 12" Eminence LTA and Chimerea Labss CCCOFC connects the Heil AMTs to the binding posts and the large oil capacitors used for the hugh passes.
Anyway I came close to doubling the length of the cable usig fewer wire that are smaller in gauge.
So far I am more than pleased with the sound and again condidering the fact that I could remove the heavy gold plated brass banana plugs out of the signal
I have measured and cut enough wire to complete anther set of cables with 14 strands each.
