Bulbs for aTU-517?
profkirby
New Member
Does anyone know where I can get bulbs for this? They are 300ma, 8volt. They are on a soft white base that pushes over two pins. Three of the bulbs in now are 150ma, I believe from (or for) a TU-317 and are not bright enough. There is one correct one bulb but it is getting dark.
Any Ideas?
Thanks
I could not find original replacements for mine. I had to use a similar with a resistor in line. I'll check later. I still have one lamp and one resistor from the purchase.
The bulbs are threaded with the same diameter and are 7V 300mA. You just have to put a resistor in.
