welcomdmat
Super Member
Hello --
I have a C712 where a bulb has gone out. I did a quick search, but I don't see the answer popping up.
Does it matter what bulbs I use so long as they fit correctly?
Do I need to replace all of the bulbs in order to keep a consistent brightness?
I had the preamp professionally cleaned/ lubed/ tested a few months ago, but my tech is not confident on these questions (in the end, they are just aesthetic).
I am happy to replace all of the bulbs -- the ones I have found are not terribly expensive. My question is whether I have found the right ones and whether I should simply replace the ones that are out and keep using the ones that are on.
Thank you for any insight.
