Burned Yamaha B-6
Discussion in 'Yamaha' started by Dominic N, Nov 16, 2018.
  1. Dominic N
    Dominic N New Member
    32
    Holland
    So I have bought something nice to restore again a Yamaha B-6 that has been on fire the inside smells terrible.
    The capacitor that should have been replaced in the recall on all 220v models has caught fire and damaged the print. image-03-11-2018_17-12-46.jpg DSC_0054.JPG
    rottalpha likes this.
  2. clinic-audio
    2,315
    France
    Yes , very well known problem
    I have made many B6
    Te-Te likes this.
  3. toxcrusadr
    toxcrusadr Omelette au Fromage Subscriber
    34,078
    Central Missouri
    You are a brave man.
  4. avionic
    46,565
    Fort Dodge, Iowa
  5. avionic
    46,565
    Fort Dodge, Iowa
    Oh boy. Hope you didn't pay a whole lot. Not looking good. Post photos after you get all that soot cleaned up. Output transistors should still be good. They're getting hard to find nowadays.
    Te-Te likes this.
  6. avionic
    46,565
    Fort Dodge, Iowa
    I have seen some of the 120VAC models burn the RIFA " across the line" caps. On M-50 and M-70 amplifiers.
    Te-Te likes this.
  7. avionic
    46,565
    Fort Dodge, Iowa
    Got a few under my belt as well.
    rottalpha, Te-Te and OnTheBlitz like this.
  8. rottalpha
    rottalpha Yamaholic Subscriber
    1,865
    Middle of Crook County
    I like your spirit of adventure :)
    not a very complex board...as in not difficult to reproduce.
    Dazaa likes this.
  9. rottalpha
    1,865
    are there any unobtanuim parts in the B-6? besides the PSU boards:biggrin:
  10. avionic
    46,565
    Fort Dodge, Iowa
    One that I know of. It looks like its probably charcoal. IC401 IG04080
  11. avionic
    46,565
    Fort Dodge, Iowa
    Well maybe not.. Its the little blue component.
  12. OMGCat!
    3,232
    El Sereno, CA
    Man those caps are bad news. I was watching a guy work on an old Macintosh computer the other day and smoke started pouring out of the case. Opened it up, Rifa cap cracked in half.
  13. Dominic N
    32
    Holland
    It is the rifa capacitor that was completely exploded and left a lot of firetracks, it is not my first amplifier that I repair but my first B-6 I now have solder all the print tracks for strength and in the meantime clean the print with some oven cleaner and let some glue flow here and there to give the print some strength again.
    There has also been someone for me who has ventured an attempt, there is also a resistance of 33k 2 watt missing.
    a new fuse holder, resistors and capacitors soldered and this is the result, not new but working fine again.
    Now just clean the amplifier board and replace 2 wrong transistors in the power control. sketch-1542436244179.png sketch-1542436321186.png sketch-1542436244179.png sketch-1542436321186.png
  14. avionic
    46,565
    Fort Dodge, Iowa
    Is that replacement for the RIFA and X2 rated safety cap?
  15. Dominic N
    32
    Holland
    yes I actually also want to have mkp but I did not have that in stock, so now these capacitors are in it.
    is it a bad choice?
  16. avionic
    46,565
    Fort Dodge, Iowa
    C401-403 VAC rated. I'd hold out for the MKP. C404 should be X2 rated.MKP ( across the line)
    Don't need any more fireworks.:D
    These are all annotated in the parts list as safety items. ( * )
  17. avionic
    46,565
    Fort Dodge, Iowa
    Is this damaged board working as it should now?
  18. Dominic N
    32
    Holland
    Aha okay I did not know, I have to replace it for the right one.
    Yes the positive thing is ..... in any case, he plays again.
    It has to be adjusted for a while but the test points on the service manual do not seem to be right.
  19. rottalpha
    1,865
    wait, what???
    you are keeping the board ???
    ya know carbon coducts electron juice, right?
    Bill Ferris likes this.
  20. Dominic N
    32
    Holland
    Yes I know, i scrubbed with sandpaper and cleaned it 5 times with an oven cleaner, there is no residue left, just soot.
    The print is good to go.
    There was also a lot of the burnt capacitor on the main board, and this has also been cleaned with oven cleaner.
