Bushmaster Assault Rifle: what do I have here?
Discussion in 'Sports & Outdoor Adventure' started by tensleep, May 23, 2017.
  1. tensleep
    tensleep AK Subscriber Subscriber
    7,000
    Dallas Metroplex
    I came across this rifle today and wanted opinions on it. Is it a good rifle, what about the ammunition, etc. I haven't had a chance to really research it yet, but AK people are usually a great resource for this type of thing.
  2. rmeade
    rmeade Super Member
    1,216
    Bay Area
    Well, the internet tells all. Its a Bushmaster Model J, originally made for use by pilots shot down and awaiting rescue. The discussion is here: http://www.l1a1.com/forums/showthread.php?t=375436
    They go on to talk about the ammunition needed, as well as a 2013 market value of about 1200.
  3. tensleep
    7,000
    Dallas Metroplex
    Yes, I saw that thread after I posted. Apparently there were so few made (under 2000) that parts are very hard to come by. More of an oddball collector than a dependable shooter, from what I gather.
  4. cgutz
    cgutz AK Member
    3,391
    SE South Dakota
    Is that standard .223?
  5. tensleep
    7,000
    Dallas Metroplex
    My understanding is that this chamber will handle the hotter rounds and larger projectiles of the mil-spec ammunition, as well as the standard .223 ammunition.
  6. whoaru99
    whoaru99 Epic Member
    40,951
    LoTL
    Yeah, isn't 5.56 stamped right on the side of the upper?
    Very generally speaking, it's typically suggested not to fire 5.56 ammo, or at least not a bunch, in a rifle designated as caliber .223. However, a recent article I read, backed with pressure measurements, suggested the ammo spec difference certainly isn't the only consideration.
    The individual chambers play in a lot too. While there is a 5.56 chamber spec and a .223 chamber spec (and variants on those like .223 Wylde), not all 5.56 chambers are the same and not all .223 chambers are the same. Depending the chamber tolerances, it's entirely possible you could fire a 5.56 round in a "loose" .223 chamber and have less chamber pressure than firing a .223 round in "tight" .223 chamber.
    But, in your case, 5.56 is the correct ammo. There is little point to shoot .223 in it unless maybe you were hunting and wanted more of a hunting style/controlled expansion bullet. As for plinking, 5.56 is usually cheaper for the run of the mill 55gr FMJ than for .223. Also, hard to say if that would have the faster twist barrel to properly stabilize the 62gr or heavier bullets.
  7. rnorton
    rnorton Super Member
    4,920
    Beautiful Rancho Malario, NM
    Semi-auto, therefore not an 'assault rifle'.
  8. tensleep
    7,000
    Dallas Metroplex
    Technically not an automatic assault weapon, but Bushmaster named it thus.
  9. usedto
    usedto Lunatic Member
    16,373
    Central Moonbeamia
    Not to get technical, but in California, if it's a centerfire rifle with a detachable magazine and a pistol grip (or one of several other characteristics) it's considered an "assault rifle".
    tensleep likes this.
  10. whoaru99
    40,951
    LoTL
    Yeah, but that's California for ya...
    bigx5murf likes this.
  11. Alobar
    5,034
    SE Alaska
    And it looks scary. ..
    bigx5murf, John James and sfox52 like this.
  12. bigx5murf
    bigx5murf Super Member
    1,083
    Las Vegas
    Why does it remind me so much of the Daewoo K2?
  13. soundmotor
    soundmotor super modified Subscriber
    Bushmaster made some weird stuff. Once upon a time I came close to owning one of these. After reading range reports much, much later I am glad I did not. The action swivels right or left and the mag rests on your forearm if you are right or left-handed. Early USAF attempt to provide pilots with a PDW more powerful than a .38 SPL -
  14. Pio1980
    Pio1980 AK Member Subscriber
    25,136
    Angel Station, Alabama
  15. soundmotor
    Those were neat backpacker guns, very light & float when in storage position. Charter Arms made them for a long time and Henry Arms makes them today.
    It's called the Viper -
    Pio1980 likes this.
  16. sfox52
    sfox52 AK Subscriber Subscriber
    3,684
    Maryland
    Same gun used by the "beltway sniper" fifteen years back.
  17. BigElCat
    BigElCat AK Subscriber Subscriber
    7,146
    South of Kansas City
  18. sfox52
    3,684
    Maryland
    You are correct, BigElCat. I saw .223 Bushmaster & thought it was the same.
    BigElCat likes this.
