thedelihaus
Nocturnal transmissions
Here's two ads for Adom GFA-535 II Power Amps-
Two different sellers, two amps, the same text in the body...
they both have good feedback, but only one of theamps can be the one described- "As for cosmetic flaws, there are six or seven small chips in the the finish along the top front edge of the fascia as seen in the photos. Also, the top of the unit shows several light scratches from other components set on top of it."
And only one of the seller is the one truly stating "Next time I'm using that rubberized shelf liner stuff under each component."
And only one can claim that "In my possession the amp has generally been used for single-person listening at moderate volume; I have never driven the amp to distortion or to thermal overload shutdown."
In these exact words, no less.
So, since the text isn't accurate, someone is being dishonest, even if only mildly so.
to one of them, :nono:
http://cgi.ebay.com/Adcom-GFA-535-I...ryZ71543QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/Adcom-GFA-535-S...ryZ71543QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
