Nice job! Looks like you put plenty of consideration into doing it right, neat, and well. Truely in McIntosh style.
Need to recap my C28's power supply due to failure of one of the three-section electrolytics - BUZZZZZZZZ! I'm going to try to mount all the replacement caps in the same space, above the chassis, that the original aluminum electrolytics were in. Have worked it all out on an engineering pad, in drawing form. And have played around with the new caps and confirmed measurements and fit. Now just need to get hold of some thin sheets of UHMW plastic and some phenolic (may just gut the old electrolytics and use their bases and solder lugs) to make up the mounting rig. Plan is to make them up in "bundles" with discs of the UHMW holding them all in the right place, via leads going through small holes in UHMW. Each 3-capacitor-bundle will replace one of the 3-section electrolyts. Negative leads on the top will go through a UHMW disc, and be twisted together (inside spaghetti or heat-shrink), and the support from the phenolic at the bottom, combined with another UHMW disc wherever it fits will make each 3-cap-bundle hold together kind of looking like a big wrapped piece of taffy. Without the wrapper. And it will all fit in the same space that the originals were in, with the positive leads all coming through the chassis in the same location as the originals, so no rewiring underneath.
Will post photos when done. But it may take a while - I've got a lot on my plate right now, also waiting on two power supply diodes from McIntosh. Might scan and post drawings in interem.
