C-70 right channel issues?
Discussion in 'Yamaha' started by Rogersjapan, Apr 25, 2018.
  1. Rogersjapan
    Rogersjapan New Member
    28
    Tucson, AZ
    Recently picked up a C-70 per-amplifier in pretty beat up shape cosmetically. It did power up and that's as far as i got to test it. I've cleaned it up inside and out with compressed air and sanded, primed and painted outside covers with some black automotive paint and now looks very nice. On to testing it. Right channel is very weak in all sources. Para tone control on or off right channel very weak. looks like some glue near the power supply area might be corroding some parts as I see some green slime on a couple resistors. Is this usually a cause for channels dropping? When I have time I want to pull out that board and give a good once over but thought I would ask the experts who have seen this before.
  2. avionic
    45,611
    Fort Dodge, Iowa
    The corrosion may be part of the issue.There are 8 little yellow/orange reed relays. One of those may have a fouled contact. Rather common for this pre-amp.
    Matsushita HB2E-DC24V
  3. pdm4606
    pdm4606 Super Member
    2,951
    Las Cruces, NM
    Welcome to the world of Yamaha rotten relay design. You will be blessed with tons of work forever from now on. Just keeping the relays working and clean. Also if they are anything like the C-50 there are a couple of flat cable activated switches located in the low signal level amp area. Just to the front of the phono inputs. Any dust within a mile of your house and it will find a way. Now I am experimenting with pieces of clear tape taped to the top of the switches. Just a guess for now.
  4. avionic
    45,611
    Fort Dodge, Iowa
    I have a couple C-70,s that are flawlessly working and sounding awesome. MM/MC direct ---> outstanding.. Inverted output is a must have for me.
    fishondwan likes this.
  5. avionic
    45,611
    Fort Dodge, Iowa
    :bs:
    Electone likes this.
  6. Rogersjapan
    28
    Tucson, AZ
    Just an update. Removed all that corrosive glue and replaced all the resistors and diodes that started corroding. Replaced all Eight of HB2E-DC24V relays as I got a good deal on them. Still right channel is very soft and have to turn balance almost all the way right to balance it out. This is all modes -Phono/aux/tuner/tape. with parabolic off or on. Swapped l and R outs and it follows. How do you get into the volume Pot area as it seems to be a sealed box?
  7. avionic
    45,611
    Fort Dodge, Iowa
    Can be disassembled. Must remove from the board and chassis. There are two long screws that hold the segments together. Remove the screws and very carefully slightly pull the segments apart just enough to get some deoxit on the ceramic plates that have the carbon resistance tracks.
  8. mbz
    mbz Super Member
    2,336
    Melbourne, Victoria
    Haven't worked on a C-70, hopefully picking one up off the bay, the schematic shows a maze of electronics, separate opamps are used for L&R channels.
    Cause could be anything. Rather than spend time disassembling/cleaning vol pot, it would be nice to confirm that it is the problem. Do you have any test
    equipment (oscilloscope, audio probe...)
  9. amr2
    amr2 Well-Known Member
    572
    Check out R349-350, they are used for gain adjustment.
  10. Rogersjapan
    28
    Tucson, AZ
    I have all the test equip. Will try to to chase signal and see where its dropping off.
  11. mbz
    mbz Super Member
    2,336
    Melbourne, Victoria
    The hifiengine schematic shows the audio path highlighted. Maube divide the amp in half and test there, the vol or balance pot wiper would be an easy test point.
    Compare L&R channels, use a low input sine wave, say 100mV, xxxHz
  12. avionic
    45,611
    Fort Dodge, Iowa
    Trivia :This is called the half - split method for trouble-shooting.:thumbsup:
    This is the method used for the testing/trouble shooting software on ATE for military avionics.
    ATE - automatic test equipment
    My airforce specialty was
    AN/ALM-173 (TISS) TEWS Intermediate Support System.
    TEWS - Tactical Electronic Warfare Systems
    zaibatsu and OMGCat! like this.
  13. Rogersjapan
    28
    Tucson, AZ
    Good test tone patterns coming into Vol pot--Low level coming out RH side. Pulled it off and opened it up and cleaned it with Deoxit. Same results -Compared both sides and RH side has 700 ohms + more when cycled through. Have new Alps 20k pot coming but cant find with long shaft. So got Pot shaft extender coming also. This should fix it I hope.
  14. amr2
    572
    The pot is in the negative feedback loop (Varigain volume control system), and the tracking error is always a problem with this topology.
  15. Electone
    Electone Well-Known Member
    768
    London, Ontario, Canada
    Sorry to hi-jack, but just wanted to say I hope you get your C-70 sorted out. I recently had a channel imbalance as well, but once I replaced all the relays, it was cured. My C-70 even managed to replace my beloved C-4 in my main system. Just an outstanding pre-amp.
  16. Rogersjapan
    28
    Tucson, AZ
    Received new Vol Pot and installed. "BINGO" right channel restored. Now to play with the shaft length right so the VOL knob will sit good. Thanks for all the tips. Another learning experience.
  17. amr2
    572
  18. mbz
    mbz Super Member
    2,336
    Melbourne, Victoria
    Picked up a C-70 with intermittent right channel. While I have not ruled out the relays as contributing/cause this example has many dry solder joints.
    Working through the tone control 1 board, with switches and pots being the main culprit then transistors... see below. I know it goes without say that
    you should check the solder joints but this one was extra bad.
  19. Oldsansui441
    1,830
    Victoria, Australia
    No, most Yamaha soldered joints from this period are extra bad, these are notorious for it. Yamaha's soldering from the very late 80's on was much better.
    mbz likes this.
  20. mbz
    mbz Super Member
    2,336
    Melbourne, Victoria
    Been a bit busy so not much progress on my C-70. Reflowed more solder joints. Traced signal ok to the
    input side of parameteric relay. Need to continue from there
    Is there a drop in relacement from a reliables source. Saw some on the bay, selling from china that were oddly
    marked made in japan...
    Oldsansui441 likes this.
