60 year old RCA's suck. They have a ceramic center piece which cracks, and the rivets get loose which makes for lousy connections. Look up the Model 24B I did last year and the R-3 I have now. I replaced them on both.
Now back to the C-800
Got home @ 4:50pm beating the Gridlock between DC and Baltimore. . It's stripped now.
Phono is a RC-121 / 4 The original variant. Not the MK-II's we're used to in the 510/610. and other units of that age which came out the next year.
Cabinet is in Very good shape. Some minor crazing of the vewneer on the
top, and the bottom edge is starting to peel no more than 1/8" to 1/4". More like little nicks in the edge than peeling. Speakers are Jensens all date coded 220705 (Feb 1957) Outstanding shape so far.
Chassis has a good heavy layer of dust on it, but NO RUST and NO Rat Trails.
The lady's father bought it new in Roanoke, and she got it in about 1990.
It's sat in her basement since 1992.
Except for the EL-84's, 12ax7, 6SC7 and 6al5, all tubes are
marked THE FISHER (even the GE Rectifier). Of the above listed tubes, only
the 6sc7 is a Sylvania. The EL-84's, 12ax7, and 6AL5 are MULLARDS with the
correct date codes for mid 1957.
SERIAL # is 10198-E. So this is a very early R-20. The Aux input is marked
TV(only). NO stereo Markings of any kind.
I got a shit load of Documentation, for both the C-800 and the Garrard. The
RC-121/4 is hung in mid cycle as the Tonearm is sprung to 1/2 way in and won't
stay in the rest position.
I'll get the Documents Scanned for posterity. Everything that JONBOY55 has on FISHERCONSOLES for the C-800 I have here with the addition of the tube layout and a lot of RC-121/4 Documentation.
Gotta find my paint brush and that new can of Scrubbing bubbles and clean the chassis. Which is UNMOLESTED underneath.
:FISHER BRANDED G.E. 5U4GA/GB
MULLARD EL-84's
R-20 Chassis 10198-E
Virgin Underside
Cabinet after Simple Green 1 to 5 with Water.
All Speakers EIA code is 220705 (5th week of 1957/FEB '57) 8 weks before my 2nd birthday............OH SHUT UP!!
Plan right now is to clean chassis, test tubes and inventory underside parts for replacement, Pull and store the Mullard EL-84's (one's getter it really thin and worn out), clean and overhaul the RC-121/4 and get a new LP stylus for the RPX. I may put a an early Type A in it. OR Drop an AT-6 in the 610 and use that RC-121 MK-II in the C-800. I have a slimline in good shape so that's a possibility too.
