C2200 Turning On Relay With 5v?
Discussion in 'McIntosh Audio' started by robertgalka, Jun 27, 2018.
  1. robertgalka
    robertgalka New Member
    44
    Winnipeg Manitoba
    Ai want my C2200 to turn on my my sequencing power conditioner. Basically I need it to close a relay with with the 5v output on the back. I tried a small mechanical relay and I believe there isn’t enough current to close the relay. Do I have any other simple options?
    Would the 5v output have enough current to close a solid state relay?
  2. CruzBay
    CruzBay AK Subscriber Subscriber
    726
    Arlington, VA
    I don't think SSR's need much current at all to activate, so you'd probably be good.
    I also saw a few reed relays on Amazon that might function at lower current levels, they specify 500 Ohms, so (Ohm) legally they can only draw 1/100 of an amp.
    Excel Cell EDR2D1A0500Z SPST-NO Reed Relays, 0.5A, 5 VDC ~ $6 +shpg
    Hamlin Electron HE3621A0510 ~ $8 free
  3. robertgalka
    44
    Winnipeg Manitoba
    I'll try one and post what happened. Thanks.
  4. dshoaf
    10,180
    RIP 1954-2018
    You could just use a simple transistor switch for this such as a 2N2222. This schematic is from a Raspberry Pi hacker's box of tricks. The GPIO pin mentioned is about the same as the C2200's output. The 10K/100K resistor divider means there's not much current required to kick the transistor on.
    Cheers,
    David
  5. robertgalka
    44
    Winnipeg Manitoba
    The reed relay worked fine. I bought a Aleph PCB Reed Relay 5V 1A SD1A05AWJ off eBay.
    CruzBay likes this.
  6. Brice
    Brice AK Subscriber Subscriber
    1,555
    Hoboken NJ
    I do it everyday with a C2500 for years.
    I have a SS DC Optical relay feeding all my tube gear.
