Hello,
I've recapped my C2a, replaced one RCA board with a new one, reflowed all solder joints and now am doing setup via the SM. I've left the MC section alone for now, and don't have an oscilloscope to do that adjustment anyways.
-PS voltage set at 40v
-DC offset in EQ section set and holds ~100mv. (SM says 0+-200mV). I'd love to replace those trimpots with new multiturn.
My problem is in the idle current adjust in the EQ section.
R channel is right around the 23mV +-10mV and stays there.
The L channel will read 0, or if the unit is power off for a couple minutes and turned on, the DMM reading climbs up to ~23mV then drops down erratically. Sometime down to ~10mV and back up, sometimes it holds around 23mV then down again, usually it ends up diving down to 0. This is with no source or amp hooked up.
I double checked all the solder joint for the L channel VR205, the TP6 and TP7 test points. I'm thinking it may be an issue just upstream but again this is where I'm no good at troubleshooting. There is a series of 4.7 resistors (R287, R291, R289, R285) just above the test points, a diode and double diode (D211, D213), and a small group of capacitors/resistors (C241, R283, R281, C239).
I've read some threads about replacing those little capacitors as they crack and cause issues, as well as the double diodes being troublesome. I'm not opposed to ordering everything and swapping it all out, but wonder if someone more familiar with this pre and this symptom could shed more light.
Thank you much in advance for your time and help.
