lowredmoon
Have any of you had success replacing the 2SA913 and 2SC1913 transistors in a C2A preamp? If so, what did you use?
I pulled the 2 pairs from the tone control board and tested them on my simple GM328 transistor tester. 3 of the 4 test with an hFE of between 90 and 100. One of them tests at 33.
I tried swapping in 2SA1930 and 2SC5157 (very close specs but 50% higher gain and higher frequency) and now the preamp will not pass sound. I also replaced the 4 VD1212 on the tone control board with 2x 1N4148 in series (correct polarity) at the same time.
I have a full set of Nichicon capacitors coming from Mouser.
The original issue that prompted the parts swapping is loud popping coming from both channels, but not both at the same time.
If I can find appropriate replacements for the TO-220 transistors, I'm going to overhaul the whole thing, within reason.
