My 124 has a newer SME tonearm and the table has been restored or in a lot of cases improved. I’m using an AT Art 9 cartridge that sells for a thousand dollars. I would be glad to put this combination up against any of your Technics tables. My question remains, how much difference would a higher end phono stage make?TD 124 is a good turntable but I have found that you need a turntable that would be closer in age to the C47. while the table is good, it's 60's technology and a lot has improved since then. Any unhappiness you may be experiencing is due to the phono stage in the C47 revealing the limitations of the turntable.
I’ve got the same amp as you. A Mac mc452. My tone arm is a three year old SME. I’ve thought about a new turntable, even went on the Sota website the other day and looked around. Again I’m enjoying my analogue rig, just wondering how much if any would a higher end phono pre help.
I have a Technics SL1200 MKI Limited Edition (Black with Gold hardware/tone arm), I slapped a Ortofon VMS20 on that and it blows my Thorens TD125 MKII with an SME into the weeds, it tracks better, less noise, better everything....
I was surprised, but I agree that in some cases new is better, and I have to say, the phono pre on my C48 is pretty damn good, you get the right gear on the end of it and it can hold its own against anything...
Don’t want to get in a pissing contest with you on who’s turntable is the best, just would like to find out if a higher end phono pre amp would be better than the one in my my C47. No one on this forum may know the answer to that.
Luv my 47 but.....haven't used my phono section....not into vinyl.
Thanks. This is exactly what I was after. I’ve compared my turntable several times to streaming Tidal hifi and on the same music my turntable sounds better. I’m sure there are better tables and arms than I have , it comes down to how much I have to spend to get better sound. I’ve heard a higher end Sota with the vacuum plater and a Dynavector 17d3 cart and it was very nice. Black background and a ton of detail, but it was also hooked up to about 30k dollars worth of electronics and some big Magnaplanar speakers in a good room.Having owned a Rogue Ares and a Manley Chinook, I can tell you with confidence, that the C47 phono stage is excellent. The Manley is one of the best phono preamps, until you spend 2 or 3 times the price. When you are at this level, and higher, the performance becomes more about flavor and what sounds good to you. With that said, I would recommend putting any available funds into a turntable upgrade, the C47 will perform.
