Caig DeOxit and Charging cables
transmaster
AK Subscriber
Subscriber
Here is a tip to try on charging cables when they start acting up. Get some Caig DeOxit D100L in the needle dispenser. This bottle will last for a very long time. Just apply a tiny amount on the Lightning plug contact surfaces, on a “C” connector a tiny amount on it’s contact surfaces. Incert the plug this cleans and lubricants both sides of the connection. You can often restore a cable doing this. This is a good thing to do periodically anyway.
You can also use Gold G100L but it does not have as much cleaning power as D100L
A friend was having a charging issue with her lighting connector.
Took a plastic toothpick and removed a big chunk of pocket lint. I am glad I did not spray anything into that connector before getting the booger out.
Thats M-1R on mine.
