So much for that concept improving the WAF. Marie pointed out that if I locate them under the CD racks, the right speaker will get whacked by the bottom of the front door. D'OH!
So that leaves me different options. I could use just one woofer per vented box which would bring my internal dimensions to 28.5"x 5.5"x8.7" which is not unreasonable, but not have the dispersion pattern of the twin woofer design. It was the discussion of this pattern in the crossover section of the book that got me interested in this design, and anyhow I'm sitting on six of these woofers I got for an earlier project that remains unfinished. Sounds like a recipe for left-middle-right to me.
The EBP for the driver is 101 which is supposed to be great for vented boxes but not as well suited for sealed. I don't know the explanation for that.
I could make a two-chamber sealed box. According to my spreadsheet, a chamber of 13 7/8"x5.5"x8" will give me a Qbox of 0.707. The online calculator agrees with this. Where they differ is that the book formula tells me the F-3dB is 52 Hz (equal to the driver's free air Fs), a Fbox of 84 Hz and essentially no dB rise at Fbox. The online calculator says peak dB at resonance is indeed 0 dB but says my F-3dB would be 84 Hz. I don't know which one is right.
I could see if the larger boxes would be acceptable. Not really betting on that one. Unless I reduce the height and make them deeper. 28.5Wx8Hx12 1/4D would give me the right volume but A. might be unsteady on the shelves and B.might become a doorstop. Ugh.
I could make dual-woofer vented boxes to fit the space and have the resulting performance. The online calculator says a box of 28.5"x5.5"x9" would have a 2dB rise at 57.7 Hz and an F-3dB of 61 Hz. Down and then back up? Odd.
Any advice gents?
