It's certainly possible. Often the "native" input on the tuners is 75 ohm, and they'd have a built-in balun to convert it to balanced 300 ohm twinlead (because that was what was mpst popular, long ago, for TV/FM "downlead").
If you have an antenna with 75 ohm coax downlead, and if you don't want to cut off the F-connector, get a female/female union for "F" connectors, an F connector, and another piece of coax with an F connector at one or at both ends. Hook one end of your "other piece of coax" to the union, and, of course, the other end of the union to the F-connector on your antenna coax. At the other end of your new "jumper", either cut off the F-connector or just dress the coax thus: strip off the outer jacket, cut (if need be) and twist the braided shield so that it can be inserted under one of the screw connectors (GND). Strip back a bit (say, 3/8 to 1/2 inch) of the center insulator (carefully) to expose the center (hot) conductor, and connnect
that to the other screw connector. Most coax has a single-strand center conductor, so you need to be careful not to nick it when you strip the inner insulator, and don't twist it with too much vigor when you attach it to the tuner
Heck, maybe you can even buy a 75 ohm coax jumper with an F connector at one end, and two bare wires (or spade lugs) at the other!
PS - I am assuming you're in the US; if you're elsewhere, your standard coax connector probably won't be an "F" connector.
