Can ESLs handle all genres?
Discussion in 'Speakers' started by ridgeway, Jul 11, 2018.
  1. ridgeway
    ridgeway Member
    55
    I'm looking at speakers and narrowing down the list. I've always wanted some Martin Logan ESLs, but I quite enjoy hip hop and pop music. Would Martin Logan ESLs happily pump out some loud rap/pop, or is that pushing them beyond their comfort zone?
  2. swechsler
    swechsler Frog Whisperer
    5,495
    7th row center
    When I saw the subject, I immediately thought that they would be less than ideal for hip hop. If you're looking for loudness, stick to dynamic speakers.
  3. JoeESP9
    17,122
    Philadelphia PA
    My ESL's (Acoustat) play plenty loud. They are rated to produce 110dB @ 18' in a 14' x 22' room.
  4. E-Stat
    7,365
    With enough panel area and power behind them, sure. Small panel models will need reinforcement at the low end via subwoofers as I use with the HT system.
  5. SiliconTi
    SiliconTi AK Subscriber Subscriber
    2,302
    New Hampshire
    Which model ESLs? Some have cone woofers to augment the ESL.
  6. frommerstop
    frommerstop Super Member
    2,575
    Detroit
    I think all current MLs except their totl CLX Art ($25,495 pr) are hybrids, using cones for bass, 'stats for highs. That in itself isn't a big deal, most box speakers use more than one driver & a crossover, done right the drivers will blend cleanly, and ML does a good job in that area. I'm not a big fan of ML because of the way they don't support older models, but they do play loud enough, and with enough bass authority to serve well on rock, large scale classical, or yes, even hip hop.
    As mentioned above, with ESLs, it's all about panel area... as long as the panel's big enough, or augumented with a cone, they can deliver all the impact you could want. Peronally, I'd suggest a 3, or 4 panel model of Acoustat over any of the MLs - way more bang for your buck, and proven better durability.
  7. ridgeway
    ridgeway Member
    55
    No model in particular. I'm on the lookout for a speaker bargain, and "martin logan" is one of my search terms at the moment. My budget will only allow a lower-end model
    With regards to panel area- is a large panel capable of producing bass without subwoofer augmentation?
