Cap importance by location...
Discussion in 'Tube Audio' started by WhiteSE, Apr 15, 2018.
  1. WhiteSE
    WhiteSE Is Lute Gluten Free?? Subscriber
    15,752
    North Bergen, NJ
    The 2 red WIMA caps soldered to the output, how important are they? why are they there?
  2. E-Stat
    E-Stat Addicted Member
    5,663
    Looks to be the output coupling caps which are very important.
    Exactly what are we looking at? Mono tube pre of some sort?
  3. WhiteSE
    15,752
    North Bergen, NJ
    Its 6SN7 stereo preamp...
    I have some Mundorf's to replace the WIMA with...I was wondering if it was worth it...
  4. E-Stat
    5,663
    Perhaps. I know that VTL uses Mundorfs in the later version of my MB-450 amps. Audio Research gear uses WIMAs in a number of places, but uses custom teflon caps for output coupling.
  5. RWood
    RWood AK Subscriber Subscriber
    1,482
    Richmond, VA
    I believe they are there to keep DC voltage from the output jacks, allowing the AC signal to pass.
    UncleBingo likes this.
  6. primosounds
    primosounds SE KT120 w/ 6J5G drivers. LCLC ps + 2 x 5ar4 Subscriber
    2,377
    Terra, 21st century CE
    In my Cary AE3 preamp. which is also 2 x 6sn7 with just a VC and selector switch. I used Vitamin Q PIO output caps. This helped to smooth out the sound some and seems to have better detail.
    WhiteSE likes this.
  7. Mike Stehr
    Mike Stehr Poverty Audio
    1,575
    East Wa.
    I have no idea what type of Mundorf caps you have to use of course, and I'm not trying to bash Mundorf caps in any way. But, I wanted to upgrade the coupling caps in a 6AQ5 SEPP amplifier. I wanted to try Mundorf, but couldn't afford the higher range supreme oil caps. I figured I would try the standard EVO non-oil metalized polypropylenes, they are rather cheap...maybe too much...
    When I was forming and fitting the leads for installation of one the Mundorfs, one of leads seemed like it broke or came unglued from inside the cap...which it did.
    I never had this happen, and I've swapped more than few coupling caps in amplifiers. Maybe I was too aggressive? Really? It didn't take very much stress to do it.
    The leads are glued to the electrodes. That might be okay in a speaker crossover, but I dunno about for coupling... I'm glad I didn't use them...
    "Don't be Vague, Ask for Sprague."
    soundmotor and Squidward like this.
  8. ConradH
    ConradH Addicted Member
    7,709
    Canandaigua, NY
    Not impressed with the Mundorf, but there's a lot of good stuff happening construction-wise in that amp shot- nice job!
  9. WhiteSE
    15,752
    North Bergen, NJ
    Actually, I used the same as you...I used the higher Mundorfs in my amps, but I did not want to spend too much...maybe I will rethink that.
  10. Squidward
    Squidward Scrappy Mod Staff Member Moderator
    4,584
    Bikini Bottom (Ann Arbor, MI)
    That's a very nice build, Mike. Love the Tek standoffs. Very clean wiring. Would like to see more of your work!
  11. primosounds
    2,377
    I believe they all do it that way for these type of caps, which are mettalized plastic conductor. The "glue is also a conductive type. I am guessing on that failed mundorf the either the glue got hard before the end cap was pressed on or the joint was dirty.
    I also have Mundorf Supreme, oil blah blah cap that sounds ok in one of my SEP KT120 amp, and it sounds decent, maybe more towards neutral? But someone gave me those caps so i have nothing at stake in how they turned out in this amp.
  12. Mike Stehr
    1,575
    East Wa.
    Thanks!
    I really need to source some 2.5K OPTs of high quality that can handle a good 90-100 milliamps of current, so I can free up my universal OPTs for bread-boarding again...
    gadget73, soundmotor and Squidward like this.
  13. Squidward
    4,584
    Wow, what an amp! Did you ever do a thread on it's construction?
  14. soundmotor
    soundmotor super modified Subscriber
  15. soundmotor
    This floats my boat. Back when I recalled which end of the soldering iron to hold I kept a 3"x5" module built by a ham. It has a single UTC A-19 on it and a tube as well as some other circuitry. I bought it to strip the UTC off but the construction detail was so superb I used it as a reference when I was tempted to rush. Your work is absolutely on par with that.
  16. Squidward
    4,584
    I try to use the little spool of solder that comes inside the Tek scope whenever I've done this. I have a Tek scope graveyard in my basement...
  17. soundmotor
    Now I need to dig one out and check for that.
  18. Squidward
    4,584
    It's a small white spool about the diameter of a nickel. IIRC it has a little nub on one side that pops in to a hole inside the chassis to hold it in place. Should be in an obvious location, usually right inside one of the removable side panels.
    Happy hunting!
  19. Mike Stehr
    1,575
    East Wa.
    Not here. I do have a build thread on the Klipsch "talking tubes" sub-forum. There's a forum member "Tube Fanatic"...Maynard is a retired television/radio repair guy who has posted many single-ended tube amplifier designs of his own on the forum. All the designs are based on cheap easily obtained television and radio tubes. Most all designs (if not all) use SS rectification and Hammond iron.
    https://files.acrobat.com/a/preview/cb79b6dd-b949-4608-9307-0b7f2ea0ceb4
    The Tek stand-offs and solder they used was silver-bearing solder if I recall. I used the Rat Shack silver-bearing solder and it worked fine for me.
