xratedpez
Super Member
Hi folks,
Restoring a pair of tri-amped Braun speaker and just got around to replacing two filter caps. The originals have a metal case with positive and negative terminals on top and have a bolt protruding from the bottom of the cap case which is bolted to the chassis/ground.
Using the DMM continuity function, I cannot see any continuity from the case to either terminal. The schematic has some strange symbols (and is entirely written in German) but I don’t see any explicit ties to ground for these caps (or anywhere else, really).
I’ve replaced the caps and it is now blowing the 1.6A slow blow fuse. Looking to see if anyone has experience with caps of this type and can explain what’s going on.
Thanks in advance.
Thanks in advance.
