stratokaster
Mental toss flycoon
Hello guys. Long time lurker but first time poster here.
I need your advice in getting the right cartridge for my Aiwa AP-2200 turntable. Before it I had a Sansui P-50 (a very basic BPC belt-drive turntable) which I used with Audio-Technica AT-95E. However, the Sansui is now dead and gone so I went out and found a rather nice looking (and incredibly heavy! this thing weighs like a ton!) Aiwa AP-2200. This is a mid-80s direct drive turntable with an S-shaped tonearm.
I mounted AT95E to Aiwa and was horrified by the sound this combo produces. Everything is muddy, the bass is too boomy and there is no imaging to speak of. Also, on warped records (even if they are very slightly warped) the cartridge starts to "dance" which never happened when it was mounted on Sansui. I suspect the tonearm is just too heavy for AT95E.
But then I remembered that I have an old Denon DL-60E cart that I got 5 years ago with Sansui. I have never actually used it because its needle is worn and needs replacement. However, I decided to try this cartridge on Aiwa. And it turned out much better than AT95E. The sound is much more "cohesive", the bass is tight and well controlled and the cartridge doesn't dance on warped records. The highs are rather dull and veiled but I think this is because the needle needs replacement.
I suspect this is because DL-60E is a much better match to my "new" turntable and its arm. Its cantilever is much thicker and more stiff than that of AT95E.
So it seems I need a new cartridge or at least a new needle for DL-60E. What are your recommendations for a new MM cart in $200 range that will play nice with a heavy S-shaped tonearm? Or should I order a new aftermarket needle for DL-60E? Also, are DSN-60 and DSN-65 needles interchangeable (they look identical and DSN-65 seems to be somewhat more available)?
Thanks in advance for your replies.
