Billysan
New Member
I have the opportunity to purchase this amp. The current owner uses it in a band setting with his PA system. I have not seen the physical condition of the amp yet. I want to use it in my 2 channel setup. I would be using a Yamaha 810 integrated in pre-amp mode in conjunction with it. Any opinions out there on this amp and/or using it for home instead of a commercial unit? I have seen two used units online develop a low level hum. Thanks in advance.
Oh, I should add, that for just a bit more I could buy the Carver 1.5 amp instead. Basically same look but with more power. I don't know what the difference is internally.
