qboneus
Senior Member
Since I hadn't shared any of these pictures here on AK thought some may be interested in what happens when you use a more modern tractor with good hydraulics with a industrial 1 3/4" ram that has been neglected in its maintenance and inspection..
This happened last week as I was operating a tractor and toolbar on one of my family's farms.
The cause of the undue stress on the hydraulic ram was the shearing of a 3/4" pivot bolt.
this bolt attaches the U shaped assembly that sits on the rear tang of the hitch which in the picture has a concrete block right next to it to the toolbar.
This point is an adjustable pivot that can be floated up-or down.
In this case it sheared,... dropping the toolbar into the ground moving at 10 MPH.
The toolbar as pictured in the first picture is not all there is,.. there's another 1 1/2 Foot underground...
So I backed the tractor back up and re-attached the Hydraulics controlling the primary ram and proceeded to try and extend the ram completely to try and float the toolbars position out of the ground. It struggled towards it's full extreme and then said "PING"
what is pictured is what is left of an ill maintained ram asked to lift more than it's share of a load..
Believe it or not this picture was taken less than 2 hours later..:yes:
tal
tal
