hey everyone i just got a cerwin vega A-2200 power amp. and this thing is hugeeeeeeeeeeeeeee. it says 900 watt input in the back.
i can't find no information on that model on google.
i called the cerwin vega technical service department
and these are the specs they gave me for it.
SPECS. A-2200I AMP
POWER OUTPUT 200 Watts rms per ch/8 ohms
375 Watts rms per ch/ 4 ohms
THD 0.15% or less
HUM & NOISE 100dB
INPUT IMP. 10K ohms nominal
POWER REQ. 120/240 VAC 50-60Hz, 900 watt at rated power
DIMENSIONS 19Wx8Hx11.5D
WEIGHT 35 lbs
But my amp dont say A-2200i. it says A-2200. i dont know how to use this thing it dont have no volume knobs or nothing in the front just 1 little switch,
i think this might be a profeshinal power amp for studio equipment.
it says sen surround on the amp. and in the back it has 1 rca plugin for each channel. like 1 red plug in on the right side and 1 white plug in on the left side.
its really big and heavy it has holes in the front of the amp so it can be screwd into something.
i really want to use this thing can some 1 please help me how do i use this. thank you all very much for your time and have a grate day. : )
SPECS. A-2200I AMP
THD 0.15% or less
HUM & NOISE 100dB
WEIGHT 35 lbs
