Clean&Tight
Well-Known Member
I was fortunate and got a nice one with no rust
Cleaned up well with mild water and ammonia solution as suggested here
Overall has a decent patina, still a little "milky" in spots like they all seem to be but very minor and just sort of "flat". Some shine but not much.
Last night, just for the heck of it, I gave an area a go with a little Nevr-Dull to see if it would take out those white spots. It pulls crap off the metal so well it turns BLACK (the piece of wadding, NOT the Fisher ) same as polishing brass with Maas of Flitz. When I buffed the area with a clean micro-fiber rag it too came up black.
After a few passes the steel begins to reflect light and the image is fairly sharp. It will never polish out to a point like a chromed Mac, but it's pretty doggone shiny.
My question is, am I causing a long term problem? Does anyone know for a fact if this steel is galvanized or what the coating is? Nevr-Dull is pretty mild, what little mechanical abrasion it has is in the soft wadding. I've seen the chassis that look fantastic after having been gone over with Maas or Flitz but I know from experience that they do remove a very small amount of material.
I have one tiny little rust speck on this entire chassis. I don't feel as if I am scrubbing away any anti-corrosive topcoat using Nevr-Dull (judging from that one spot) but I don't know for sure. It's not like lacquer; Nevr-Dull will remove that if you're persistent! That extra level of shine is nice but not worth causing harm. I would only do the large areas anyway; leave the lettered sections alone.
I did do my tuning cap cover and tube shields with Flitz. They look great, like stainless now. But the rag was still coming up black when I finally said "enough!". I finished those off with a little car paste wax after polishing.
What do you think? Overkill? Am I removing the galvanization? Or is it even galvanized? You know how the interior sections still have quite the shine and there are areas of these old chassis that would lead you to believe that when new, they did in fact "shine" quite a bit.
What gives me pause are things like that tuning cap cover and the ventilated cover for the speaker select switch. Their dull flat patina is just that, but homogeneous and smooth which would make me think they were that way from day one, but they are also obviously from a different stock and gauge of metal.
I'm definitely up for doing the sides until they gleam, but don't want to screw things up. One of those easier to do than undo choices.
Thomas
Thomas
