Cheap little microscope
Discussion in 'Turntables' started by Nixxuz, Jun 27, 2018.
  1. Nixxuz
    Nixxuz AK Subscriber Subscriber
    905
    Minnesota
    So I got one of those cheap USB microscopes from Amazon, as I was curios as to what condition my stylii are in. I'm not sure how good it is for that specific task, especially with the garbage "stand" it comes with, but at least it takes pics!
    AT3482P profile;
    Ortofon 320 profile, (brand new out of box)
  2. restorer-john
    restorer-john Addicted Member
    6,744
    Australia
    Realistically, those cute little USB scopes are for kids, looking at bugs and spiders. They will tell you if you have a diamond, but sadly, the condition of said diamond needs considerably more magnification and resolution.
    They can be used for PCB joint inspection however.
    They are fun though. :)
    WaynerN, CruzBay, janikphoto and 2 others like this.
  3. wualta
    wualta permanently nonplussed cat Subscriber
    7,526
    West Michigan USA
    These USB scopes can also tell you when your diamond needs a bath (like the Ortofon above), and that's important to know.
  4. Blue Shadow
    22,328
    SE PA
  5. Nixxuz
    905
    Minnesota
    It's actually somewhat useful with a proper stand, as I found out.
    Not perfect by any means, but better than the little mag on my Zerodust!
    janikphoto likes this.
  6. Blue Shadow
    22,328
    SE PA
    Yes, you will be able to tell if you cleaning regimen it adequate at keeping the stuff off the stylus.
  7. Nixxuz
    905
    Minnesota
    Getting even better as I figure it out. I'm guessing a person could see some wear if given enough light sources. This is that same Ortofon 320.
  8. stoN_Cold
    stoN_Cold Super Member
    3,468
    Belgrade, Serbia
    Nixxuz likes this.
  9. Nixxuz
    905
    Minnesota
  10. 50nstillhifi
    50nstillhifi Super Member
    1,124
    Carolinas
    Its been said... "practice makes perfect"... I have to try mine out :idea:
    Nixxuz likes this.
  11. stoN_Cold
    3,468
    Belgrade, Serbia
    Like girl. :rockon:
  12. Blue Shadow
    22,328
    SE PA
    To find out what you need to see to determine stylus wear you can google images, check out the OM for the Shure SEK-2 on VE or check of the sticky in the big TT projects sticky for Sparky's stylus microscope build thread.
    I'm sorry but there is nothing enlarged enough to see stylus wear in those pics. When using a stylus wear evaluation magnification there is such a short depth of field that one only sees part of the stylus, a very small part.
    These pics in this thread are nice to see the overall stylus/cantilever condition but not stylus wear. These devices keep getting better and may one day put stylus wear evaluation into the hands of the masses.
    These are nice photos though and with proper lighting show stylus mounting and general shape. There are more and more nice needle pics showing up on ak using these devices. Keep up the good work.
  13. Nixxuz
    905
    Minnesota
    I dunno. Top one is 3 months old and the bottom has never been used. The Zerodust is doing it's job, but gunk still can build up...
  14. Blue Shadow
    22,328
    SE PA
    Need better stylus cleaning, not that what shows is going to contribute much to the sound. I like a Discwasher SC-1 or 2 and dampen the leading edge that touches the stylus first. Drag the stylus through that and it picks all the crud of the nail.
  15. Thunderbox
    Thunderbox Well-Known Member
    617
    Saskatoon, Saskatchewan
    What is the magnification of your microscope
  16. Nixxuz
    905
    Minnesota
    It supposedly goes from 40x to 1000x. I can't see any way to prove any of it. Like I said, $20. Just came in a box with a terrible stand and a driver CD that I can't use because I don't have a disc drive on my PC. I bought a better stand for another $20.
  17. stoN_Cold
    3,468
    Belgrade, Serbia
    Sony VM-22GA
  18. Nixxuz
    905
    Minnesota
    Ortofon OM14 I got from another AK'er.
  19. Thunderbox
    617
    I ordered one just the other day. Will be interesting to look at all my styli specially the ones I suspect as being worn.
  20. KingBubba
    10,168
    Brooksville, Fl.
    How about a pic of the microscope itself?
