Checking Cross talk with Oscilloscope and other things
Discussion in 'Turntables' started by Nashou66, Apr 11, 2018.
  1. Nashou66
    Nashou66 AK Subscriber Subscriber
    2,042
    West Seneca NY
    So I recently did a re tip of an Acutex stylus with a Shibata tip and also an Entre' EC-20 with an generic elliptical.
    I wanted to see how well I got the azimuth right of the cantilever/stylus assembly . Listing and visual inspection can only go so far. So I thought i'd finally pull out my O'scope and put it to use
    on my Acutex re tip. Before I pulled out the scope I wasn't happy with the alignment so I re did it a few times ( you can adjust the alignment a bit on these styli ) till I got it as best I could with visual inspection.
    First let me say using the Analog Productions test disc right after the initial re tip left the balance to be desired. It seemed way off. after a few re visits tot he work bench it got much better but I am at my limits adjusting the stylus assembly with out removing the cantilever and doing it over. Have not tried to remove super glue before on a stylus and not sure I want to with the delicate suspension components right there to be exposed to the acetone.
    So now to the three O'Scope pictures I took. Its not to bad. A little louder right channel but nothing you can tell and with an adjustable head shell you might be able to dial out any imbalence , I'm testing on my AR XA . no adjustment for azimuth here. But I do have to re visit with different VTF as these Tri Pole designed carts
    are fussy to VTF and channel seperation .
    First is both channels with a 1 kHz sine wave. .2 volt/div and .5 sec/div
    here is the left channel signal only and the right crosstalk below , not to bad I think.
    And the Right signal with Left crosstalk.
    Pretty cool I think.
    So what else in Cartridge set up can you do with an O'Scope guys?
    Athanasios
  2. JP
    JP 7480 74111110101115
    2,670
    NYC and Brookfield, CT
    Not bad at all. Nicely done.
    Nashou66 likes this.
  3. c_dk
    c_dk Addicted Member
    6,569
    West Michigan
    Anti skate, tracking ability, channel seperation for the whole frequency response of the cartridge, frequency response linearity, basically with the correct test records all parameters of proper cartridge calibration.
    Bill Ferris, malden and Nashou66 like this.
  4. JP
    2,670
    There's a Linear Audio article that details a lot about turntable setup and covers scope usage pretty well IIRC. All the info is out there, but it's nice to have it in one place. My copies are at the house - will try to find which one this weekend.
    dbxdx5 likes this.
  5. c_dk
    6,569
    West Michigan
    While I continue to use the same Tectronics scope I've used with my Sound Technology distortion analyser for 40 years, I have been experimenting with a laptop based scope for cartridge calibration.
  6. JP
    2,670
    Via sound card or proprietary hardware?
  7. c_dk
    6,569
    West Michigan
    Cheap Berringer USB sound card. Have fed it with my Shure C-pek as well as a preamp phono stage. Still have all my 40 year old test records but have been experimenting with some modern replacements.
  8. JP
    2,670
    I bought a "normalizer" kit. It makes the output around 1v which is the most linear range for a lot of prosumer external sound cards, like the Scarlet 2i2. Supposedly you can get very close to dScope level instrumentation, says the guy who designed it, that also owns a dScope. Hope to play with it soon.
  9. c_dk
    6,569
    West Michigan
    Not trying to unravel or unpack complex analog data streams......for evaluating RIAA compliance a known phono stage and my Soundtech 1701 does that job.
    Have been experimenting with unraveling the noise spectrum of 40 year old vintage preamps with it though has been interesting. I still use my old passive reverse RIAA circuit for this test.
    Bill Ferris likes this.
  10. JP
    2,670
    Ah. I do RIAA in the digital domain.
  11. Nashou66
    2,042
    West Seneca NY
    Or you can do this !!!!!.................
    :D
    Nashou
  12. Thomas_AA
    Thomas_AA Active Member
    181
    Sweden
    Note that the results that you get is dependent on the test record that you use...
  13. c_dk
    6,569
    West Michigan
    The first steps of any testing procedure is to correlate how your past measurement procedures compare to your new attempts.
    My test records go back to 1978 so I have been comparing some newly available test records with the industry's old standards.
    It is not only the records themselves that are getting old, just like when the records are worn out those of us who learned how to use them, most often taught to us by those who started the high end audio business, well, we are getting worn out too.
    Most of my vintage test records sat fallow for most of twenty years......no client interest for the most part.
    I have been gathering new pressings to compare to the old and when I have found viable alternatives trying to pass on those that best measure up.
    Bill Ferris and malden like this.
  14. JP
    2,670
    There's a thread on diyAudio about test records you may be interested in.
  15. lini
    lini just me...
    6,045
    Munich, Bavaria
    N66: Looks like about a 10:8 ratio and hence a difference of ca. 2 dB - so quite ok, I'd say.
    Greetings from Munich!
    Manfred / lini
  16. Nashou66
    2,042
    West Seneca NY
    Yes It does sound good to my ears.
    I wish I pulled out the scope when I could hear the difference and took screen shots of that.
    The Analog Productions Disc is pretty useful. It also has a Distortion test but I need an analyzer for that.
    I have an original STR that might be worn some. I'll take a reading of that later today when I get home from work.
    I should hook up a cd as well with the 1khz sine wave to make sure its not the pre amp section that is off.
    Athansisos
  17. damacman
    9,244
    Gilbert, AZ
    Sure beats a light organ ...
  18. c_dk
    6,569
    West Michigan
    Most of the test records out there are feeble attempts to allow a end user to try to judge setup via listening to their speakers. This of coarse adds all the issues of the speaker and it's room interactions to color the process.
    Some of the cartridge suppliers back in the day offered dedicated test records for the trade as well as those intended for home use.
    I have been trying to sort through new releases that might have tracks than can be used with today's test equipment but there very few of them.
    Any suggestions are welcome.
  19. Nashou66
    2,042
    West Seneca NY
    This is the one I use. Click Pic.
    needlestein likes this.
  20. Nashou66
    2,042
    West Seneca NY
    Ok interesting find here.
    Same Cart but with Original 312 STR stylus. It has much more amplitude . Same settings on Scope.
    Could it be the ferrous material used for the channel "ears" and cantilever third pole exciters?
    I couldn't get the signal to stay triggered here, pic snapped when it let loose. Oh well you can get the idea.
    Left channel signal with right channel crosstalk
    Right Channel signal with Left channel crosstalk
    Athanasios
