Bought it without tubes as I have plenty of 807s and 6SL7s. Still burning it in so will give it a few more days.I do like the hand drawn schematic.
Before the usual crowd pile on and tell you it's from China and is crap/was made by 8 year olds in a sweat shop etc. and you should throw it away I would usually suggest playing it for a while and trying some different tubes and coupling caps but assume from your post you have already upgraded the tubes. So maybe some better coupling caps?
That's the secret.I have bought a few amps from China, have never had a crap one yet as I do my homework first.
Are you a kiwi mate?That's the secret.
There's some good stuff out there if you look and do some basic research.
Don't see many Raits on here!
Sold mine many moons ago and still regret it!
Have already done the grommets, The chassis wasn't grounded when I got it ! First thing I fixed. Changed the earthing at 2nd C neg at the same time.You may want to use discrete, low-capacitance, shielded cable for the input channels - you may have cross-talk and high frequency loss. And possibly some shielding between the input sockets and the nearby speaker output wiring.
Double-check the ground wiring around the CLC B+ filter to ensure circuit grounds are taken from the second C neg terminal. Where is chassis grounded, and are the speaker outputs grounded?
What does the on/off switch switch? It looks like mains AC wiring passing nearby the 807 socket.
How does the 807 anode lead pass back through the chassis? The chassis doesn't use grommets, so hopefully that lead is suitable voltage rated, with extra insulation through the chassis.
Yep, from Chch and have seen the "factory" so know what you mean. definitely a good amp.Well, I've been away for about 12 years, but yes, I supose I'm still a Kiwi. I still travel on that passport ...
Have had my Rait since 1977 or so, and it's currently back in play. A really great amp. Got it from a contact at the factory, if you can call the setup they had a factory ... Had it refreshed a while back and it should go for another 40 or so years.
Assume you are a transplant as well?
Thanks Paul, a schematic for the SRPP would be great.Will check the voltage on G2, possibly a bit high now I have dropped a 5V4G in there. Might try LED bias on the 6SL7 as well but will try your suggestions first.There is bunch of changes you can make to this amp!!! I would do the following (my own sense of priority) changes:
1. Add local NF from the plate of 807 to the plates of the 6SN7/6SL7 (a 200K resistor)
2. Regulate voltage on G2 of the 807. This could be done in a number of ways, the most easy one using a resistor and a string of Zeners,totaling 300V (max voltage on G2).
3. Change the input stage from parallel plates to SRPP (I built both, and like SRPP better, YMMV)2
3. Install a Triode/UL/Pentode Switch...
If you need schematics for any of the mods, please let me know, I will dig it out and post it.
Cheers, Paul.
Unfortunately the only test gear I have are my ears and a multimeter, might be time to invest in a scope.hm, no feedback anywhere. Bypassed cathode resistors too, so nothing local. Me being me I'd probably provide it with feedback, even if it was just removing the cathode caps to provide local feedback at each stage. The gain will drop considerably though, so it might require rewiring the 6SL7 to be 2 stages of gain vs a paralleled tube like it currently is.
of course a first step is a performance evaluation to see what its even doing now. Power output, frequency response, along with THD and IMD tests if you've got the gear.
My experience also with the best I've tried so far being my Oldchen K3. Incredible with Tung Sol KT120, 2x Shuguang CV181-Z Treasures and 1x Melz 6H8C hole plate tubes, coupling cap and volume pot upgrades. Will have it switchable to triode eventually too
View attachment 1021383[
Yep the only problems I have had has been electrical earth not grounded to chassis. A common problem with overseas amps and the first thing I check.My experience also with the best I've tried so far being my Oldchen K3. Incredible with Tung Sol KT120, 2x Shuguang CV181-Z Treasures and 1x Melz 6H8C hole plate tubes, coupling cap and volume pot upgrades. Will have it switchable to triode eventually too
Thanks Paul, just checked out your FB page, hmmm I have a bunch of Gu50s I picked up cheap about a decade ago, I can see another project coming up!Attached to this post is an example of 807 with SRPP front end. The schematics is in Russian, but no translation is needed, I believe.
Cheers, Paul.
Thanks, I will check out the used market here and see what I can findShort of that, a good accurate meter that will do up to 20khz and a signal generator can get you freqency response plots. Its tedious, but it can be done. I'm now down the meter, so its back to the analog in the THD analyzer for voltage readings now. On my list of things to do is upgrade my test setup, maybe actually end up with something automated so its not 20 minutes of pushing buttons and recording results in a spreadsheet, then having it math it and graph it for me every time I change something and want to see what it did. Its just tedious.
