Looks like it uses fixed cathode bias rather than adjustable grid bias. Fixed bias is OK but grid bias is preferred.
I don't mean to nitpick but, just to clarify, because it IS confusing . . . "fixed" bias and "cathode bias" are two different things.
The term "fixed bias" actually refers to the type that is adjustable. Not sure who came up with the choice of terms. Perhaps they were thinking that you could "fix" the bias to whatever point you like.
Cathode bias is not adjustable. It is sometimes referred to as "auto bias".
As with most things, they each have their advantages and disadvantages.
Nice to see its mostly point to point wiring. Looks like a very well thought out design.
Even though there is a lot of point to point wiring, good luck finding a replacement if one of the boards has a problem. Not necessarily a deal breaker but it's something to consider. Of course, this holds true for pretty much any product that uses circuit boards. The unavailability of replacement boards, even for stuff made fairly recently, results in many products ending up in the scrap heap. All point to point is really the way to go.
Your opinion about the specific model posted would be appreciated, as well as any suggestion regarding alternatives.
This amp does look to be a considerable step up from the cheaper Chinese offerings.
That said, it's difficult to even find a schematic for most Chinese amps much less factory replacement parts. Maybe this company is different and has replacement boards for sale. You might want to ask before you buy. It would be a lot easier to have a replacement board sent to you than to have to return the amp to China for repair, assuming that the factory even has a service department, which is very unlikely.
At that price level, I'd consider spending a little more on something like one of the Dynaco clones. If the circuit board is damaged they are readily available. And if you're planning on doing some mods to the Chinese amp, you're getting even closer to the price of the Dynaco clones, which (I believe) can be ordered with "upgraded" parts.
I'd also suggest that you at least take a look at some vintage alternatives. Most are all point to point and, more importantly, vintage gear appreciates in value.
