willhowl
Well-Known Member
Greetings,all. I have searched the forums for the following terms- chirping,squealing,squeaking- and found nothing. I pick up old tapes quite often and find a lot that have these problems.
The noise is both mechanical- ie. in the case- and also shows up sometimes in the signal.The two problems don't always go together, but often do.
Any thoughts? I have sometimes "fixed" mechanical squeakers by gently twisting, or torqueing the plastic case by twisting it by hand- again,very gently. I may hear a little "pop", and then,it works!!Sometimes not,also!!!
Thanks for your responses..............willhowl:thmbsp:
