Bert 1100
Super Member
I am doing a series of restorations of late 70's HH Scott amps for a nice gentleman, and he asked if I was interested in a half-working Rega Apollo (non -R) for free...how could I refuse !
The player is nearly like new, but it has issues properly reading discs... or had issues !
When I got it, the player did not even recognize the first disc I gave it, then another it did recognize but skipped and would not play all tracks.
The lens looked perfectly clean, but I did give it a very gentle wipe, moving the lens around a tiny bit (gently !) to maybe give it some more freedom of movement.
Then with the help of a toothpick dipped in WD-40 I very carefully put a drop or two of the stuff on the rails of the laser carriage (both sides) and on the visible plastic gear.
I also put a drop of wd-40 on the top motor bushing. You can access it after gently pushing the laser carriage away from the center (DONT push on the lens but on the housing !!!)
Also I have not switched it off for two days now.
All of this was done without taking anything apart.
And now it seems it is playing everything fine !!! even recorded CD-R's
I hope it will continue like this....fingers crossed
And the sound ? Beautiful ! my Marantz CD6005 is easily bested I fear.....
And I like the look of it as well !
Here it is, sitting on top of my Marantzes...
