Just got a semi-nasty MC-2205 that has a medium amount of ferric oxide on the top, around the caps and 'sinks. I tried a little to get it off, around the +/- 3/8" top edge of the sides and back. Used 3 different types of chrome cleaner and all did about the same. That is, some pits and bumps are left that can be felt with your finger. Not good. :worried: Doesn't look awful, but getting very close.
This a.m. I phoned a client here in town that is a commercial plater (and a casual friend) and asked him about it. He said that no matter what you do, the rust is still there, on the surface of the steel and there's no practical way to stop it other than stripping off the various layers of plating, polishing and re-plating. He offered to re-chrome the chassis and I'm considering it now. I asked if he was familiar with anyone that could do the silk screening and he was not.
I spent about 1/2 hour staring at the bottom wiring of the 2205, all the while being on guard that it didn't fall over (I had it on its side) and sever my hand or crash through the floor. Actually, it doesn't look impossible as a lot of the wiring is plug-in and it looks like not a lot of unsolder/solder would be required. And, yes, I've got the correct semi-tubular rivets and an appropriate rivet smasher.
The only thing I'm concerned about, other than a lot of work putting it back together, is the loss of the lettering on the back. It would also give me the opportunity to re-paint the transformers and the sheet metal - after I figure out a way to get the "decals" off and back on again without damaging them.
It seems to me that this would be a fun project and not too expensive as I can probably get the plating done for free. I'm not a very good painter and may get soemone to do this for me as I'm sure the results would be a lot better.
Any thoughts on this? Suggestions?
