Circuit board cleaner?
Discussion in 'Solid State' started by PAUL Camden, Dec 7, 2018.
  1. PAUL Camden
    PAUL Camden Member
    82
    What kind of cleaner solution would a guy use to wash down solid state circuit boards?
    I have an amp I want to clean up that has a lot of dusty gunk on the inside.
    Thanks
  2. Jeff449
    Jeff449 AK Subscriber Subscriber
    243
    Silver Spring, MD
    I use 90% isopropyl alcohol and a brush. You can use an old toothbrush if you don't have one made for electronics.
    Deoxit works too, but is expensive.
    Bill Ferris likes this.
  3. richs8778
    richs8778 New Member
    33
    lincoln ne.
    i just carefully give it a good bath with small paint brush & hot soapy water , rinse & set out in the sun to dry. then clean the controls with deoxit , probably have to pull the front panel off & give a good wipe down with glass cleaner. never had a problem.
  4. Marine0811
    Marine0811 I love it loud! Subscriber
    Try a dry toothbrush first. Just go easy. Most dirt and dust will come off dry
  5. PAUL Camden
    PAUL Camden Member
    82
    Just ordered some wd 40 electronic cleaner. 6.50 a can, may try to rinse with some hot water in a squirt bottle.
    its a pioneer spec 4 amp and the boards come out pretty easy. I will see if the wd 40 loosens the grime. May try some
    hot water and dawn detergent. looks like this thing was in a nicotine environment.
    Everything gets sticky then the dust fuses to it.
  6. jheu02
    jheu02 AK Subscriber Subscriber
    3,185
    North Carolina
    Simple green is also good when really gunked-up.
  7. merlynski
    merlynski Curmudgeon Electronicist Subscriber
    771
    High Plains, Eastern Colorado
    Don't use WD40, it is not intended to be an electronics cleaner, it removes water, lubricates and leaves a residue.
    Here is how I did it with a really filthy SX-780.
    Remove wood covers and other likely to be damaged-by-water parts.
    Take chassis or boards outside, and set on hard surface so liquids can drain away.
    Saturate with Simple Green and let it soak for a while.
    Rinse it with water, you can brush with a soft brush if needed. Be careful not to flood it, just rinse and drain.
    Repeat Simple Green and rinse/brush treatment if needed.
    Blow away water with compressed air or similar, gently, don't blast it real hard, it is not necessary.
    Rinse down well with isopropol (99%) or denatured alcohol to remove the last of the water.
    Blow dry gently again.
    If it has a receiver with mechanical tuning capacitor rinse the fins with a non-residue electronic cleaner.
    Let it sit in a warm place overnight, to finish drying and alcohol evaporation, A warm incandescent light bulb and/or fan helps.
    Deoxit switches and controls with appropriate type.
    SX-780 before clean:
    SX-780 after clean:
  8. patra710
    patra710 Active Member
    235
    Beecher, IL
    I use a shop-vac and duct tape a small hose to the one of the attachments, like a fish tank hose. Then use windex or simple green with a acid brush and scrub down the board staying away from the pots and coils. Get it nice and wet. Then vacuum it off. I do this a couple of times. Then let dry. I do use different size hoses so some will fit over caps and transistors and smaller ones to get into tight spots. Works great to get the 1970's party smells out of them.
    dlucy and merlynski like this.
  9. Watthour
  10. mkane
    mkane AK Subscriber Subscriber
    6,605
    103 miles N. of S.F.
    ultra sonic bath
  11. Hipocrates
    Hipocrates Anti-Muppet Subscriber
    1,944
    Costa Rica
    man that's some nice grime, courtsy of WD40 + dust+smoke I guess?
  12. merlynski
    771
    Yup, it was my shop music stereo for over 10 years, where I worked on motorcycles, trucks, cars, etc.: Wrenching, cleaning, grinding, cutting, welding , painting, exhaust fumes, wood stove smoke, Colorado wind-blown dust and grass fire smoke, mice and cats wandering around, a dog or two, an occasional bird flying by, just the usual shop residue.
    mkane and avionic like this.
  13. Hipocrates
    1,944
    Costa Rica
    Awesome!
  14. redk9258
    redk9258 AK Subscriber Subscriber
    1,640
    Illinois, close to St. Louis.
    Deoxit is for controls, not circuit boards.
    WD40 sells different formulas now. They have a non residue cleaner. Of course keep the original WD40 away from electronics!
    https://www.wd40specialist.com/products/contact-cleaner/
    PooreBoy and merlynski like this.
  15. jheu02
    3,185
    North Carolina
    You SX-780 ws even worse than my Ugly Betty Kendwood Basic M-1...
    dlucy likes this.
  16. Tim D
    Tim D AK Subscriber Subscriber
    1,523
    Melbourne, FL
    Poster was not talking about the basic WD-40. He was talking about this....
  17. savatage1973
    6,836
    NW Pennsylvania snow belt
    Sorry, I can't track down the pics (or even remember if I kept them), but a few years back I bought a couple Carver PM 1.5 (fan cooled pro amps) that had been used by a band that specialized in "barn dances"--as in being held in actual barns full of hay. Filters got clogged, so they pulled them--didn't replace them--just pulled them. You should have seen what was inside.
  18. PAUL Camden
    PAUL Camden Member
    82
    Im not talking about regular wd 40. they make a electrical contact cleaner like deoxit
  19. PAUL Camden
    PAUL Camden Member
    82
    right
  20. PAUL Camden
    PAUL Camden Member
    82
    Actually simple green works good on nicotine
