MCM_Fan
AK Subscriber
I have a pair of Vandersteen 2CEs that are in perfect functional condition, and other than some dirty socks are in otherwise very nice cosmetic condition.
However, the socks need cleaned. They don't have any tears or snags, and I've seen the threads on the amount of work required to remove/replace the socks. I wish to avoid that and clean the socks in place.
They aren't so much stained as they are soiled from dust. It looks like a prior owner may have tried to clean them with a damp sponge and just managed to further embed the dust within the weave of the fabric. This is especially true of the little top rectangular panels.
I read a comment on the Vandersteen forum from Richard Vandersteen himself where he recommends:
"I WOULD SUGGEST USING A SPRAY FABRIC CLEANER THAT DRIES INTO A POWDER. WHEN DRY, USE THE BRUSH ATTACHMENT ON YOUR VACUUM CLEANER AND CAREFULLY REMOVE THE DRIED CLEANER."
Sorry for the all caps, I cut and pasted his exact response (evidently, Richard has a stuck caps lock key on his keyboard).
In any case, he doesn't specifically mention which brand of spray on fabric cleaner to use. Does anyone have any experience using these cleaners with black grill cloth? I don't want any fading, staining or streaking. That would just make them worse than they already are.
Also, is it best to wipe them down with a damp sponge before (or after) applying the fabric cleaner?
I don't want anything running down onto the drivers. So, I plan to raise the rear of the speakers slightly so that they are tilted forward during the cleaning. I will also lay them on their backs and raise the opposite end while cleaning the little rectangular panels on the top of the speakers. These are actually the most spoiled and will probably require the most work - maybe a second application of the fabric cleaner.
If you have any experience cleaning Vandersteen socks, or any other black grill cloth that can't easily be removed, please chime in with any hints, recommendations, products and methods than have worked for you.
