faber12
Addicted Member
I have a Sound Blaster Audigy SE I use in my PC, it is a low profile sound card that has coaxial digital out via one of the 3.5 mm jacks. It supports 7.1, although I only use it for 5.1/2.0.
I have used this card successfully with a Sony STR-DG510 for years. I use a mono 3.5 mm to RCA cable to connect the card to the coaxial input on my receiver.
I also have a Rotel RSX-1056 that I can hook up this way, but I have a heck of a time getting it to work correctly. It seems to be very picky about what cable I use. I can only get it to work with a super cheap 3.5mm to L/R RCA cable, using only the right side RCA to the coaxial at the receiver.
Even when it does work, there are audio dropouts that are associated with things turning on in the house. When the central air turns on, when the burners on the electric range cycle, etc.
I never had this issue with the Sony receiver. Any old cable worked, and never a dropout, always a rock solid connection.
Any suggestions for how to remedy this? The Rotel sounds better than the Sony, and has more digital decoding features as well, or I would just reinstall the Sony.
Thank you.
Thank you.
