When you say you have Column II on one channel and 1001A on the other, I assume you mean you have a pair of Column II hooked up to the "A" set of speaker outputs, and the 1001A hooked up to the "B" speaker outputs? Any particular reason you're running both at the same time?
I ask because the Column II is a much better speaker than the 1001A (it retailed for 6 times the price), and I know from experience that it runs very well, and gets plenty loud on half the power you have. And sounds great doing it. It's a pretty easy load on an amp.
Also in my experience, running two sets of speakers at once tends to muck with the overall sound quality. The frequency response of both speakers start messing with each other and overall sound quality is reduced.
If I were you, I'd ditch the 1001A (or move them to a secondary system) and just play the Column II. It will take significant load off the amp, and you may very well find you like the sound better. Don't worry, they'll still get plenty loud.
