Mr Natural
Malmborg in Plano
Ok all you Geeks out there........
I just replaced my 300Mhz P2 with a 800Mhz P3 (Dell).
Installed my 2yr old Yamaha CD-RW, set to slave as the oem CD player is master. Windows 98 2nd edition.
Upon bootup, the bois sees both on the first dos screen. However.......in the device manager, only the Yamaha is seen as a CD rom only . the orig CD does not work and my CDRW will not record.
I am about to pull the yammie and reboot so only the oen CD rom will be recognized. Then I will install the Yamaha and rebott again in hopes it will correctly recognize it and all will be well.
Any thoughts on this...I need to burn stuff.
thanks.
Mr. Snatchural
thanks.
Mr. Snatchural
