I want to make my own sub and satellite system to run off my soundcard. The Infinity and JBL powered subs I'm looking at have RCA line-in and a block for speaker-level in and out. I thought I could go from the soundcard to the line-in and run 2 5" bookshelf speakers from the speaker-out block, with the sub's amp powering the speakers. But after looking at the JBL's on-line manual, I don't think it will work.
Appearently, you have to run speaker-level in in order to use the speaker-level out. The signal goes through the sub without being amplified. Are all powered subs set up this way?
Is there a way to do what I want without using a separate amp for the satellites?
Bob
Bob
