birchoak
Hi-Fi Nut
Just when I thought I couldn't be impressed by another humble-watt receiver, in walks a Concept 2.0 receiver. It is both well-designed and well-made, and despite being near the bottom of the Concept line, no corners were cut in this fantastic machine.
It pulls in perhaps the strongest, richest FM I've yet to hear from a receiver, and that is in my basement without an antenna hooked up! Sound is clean and strong, but in the right channel only. This holds true whether it's FM or TAPE (this guy does not have AUX). I did some common sense troubleshooting and some initial steps to find/solve the problem:
1) Thoroughly cleaned the switches and pots (as best I could--I am reluctant to open up any switches but feel confident I got the pots cleaned good).
2) Tested whether problem goes away in mono. It does not go away in mono.
3) Tried the other speaker terminals. Nope, left channel still very weak and distorted. Problem not in my test speakers, either, as they check out with other equipment.
4) Looked for anything obvious-- burned out, loose, cracked, bulging, etc. Everything looks good--it is a very clean unit and I don't think anyone's messed with it.
5) Tried using it as a preamp and it's perfectly ok as such, so I'm reasonably sure that the power supply, filter caps, and preamp sections are good.
And here's the impressive thing. This humble receiver has so much, um, presence, that it's hard to tell it's only firing on one channel. Only by shifting balance to the left channel can you hear the bad channel. It is very, very weak and distorted, like when you aren't properly locked onto a radio station for example, and does not vary no matter what knobs or switches I manipulate.
It is such a cool receiver that I started recapping it (I know, I know--caps very likely not the problem and certainly NOT the right way to approach repair, but I had a bunch of caps on hand). Replaced the big filter caps, part of the power supply, and every single cap on the R and L power amps. Recapped the teeny PRE/MAIN board clinging underneath the chassis. All caps same capacitance; voltage bumped up maybe 20% on a few caps. Nothing seems amiss and I have yet to find a solder joint that doesn't look good. And oh yeah, it passes a dim bulb test--no problems there.
Any ideas, oh masters of the electron? It is a honey of a receiver and I don't want to see it gather dust in my closet of shame.
