Hi Ron, I replaced the original Bridge Rectifier with a beefier Sylvania ECG169 - 2 amps and 600 volts. The preamp worked for more than a month and then the left and right channels began to distort a bit and fail. The only way I can get both channels to work is to lightly tap the board near the relay, or to manually actuate the relay myself. I don't think the new Sylvania Bridge Rectifier failed, do you? The correct current seems to be available everywhere else, and this is evident when I manually actuate the relay.. Why would there not seem to be enough voltage/current to the relay coil?CJ PV-7 rectifier
It's a BR805D rectifier used in the filament and turn on delay power supply. Rated at 50 volts and 2 amps. If you can't find a schematic, send me a PM with your email address & I'll send you one that is nearly impossible to read but that's all I have.
Ron
Try resoldering the relay and clean the relay contacts . I have used 600 or 1000 grit sandpaper soaked in deoxit. Pull thru the closed contacts a couple times .Hi Ron, I replaced the original Bridge Rectifier with a beefier Sylvania ECG169 - 2 amps and 600 volts. The preamp worked for more than a month and then the left and right channels began to distort a bit and fail. The only way I can get both channels to work is to lightly tap the board near the relay, or to manually actuate the relay myself. I don't think the new Sylvania Bridge Rectifier failed, do you? The correct current seems to be available everywhere else, and this is evident when I manually actuate the relay.. Why would there not seem to be enough voltage/current to the relay coil?
Already resold red last week. I was a little careless with the deoxit. Sprayed direct to the contacts yesterday. Applied compressed are to remove excess, and that made my problem worse. It was then that I discovered the relay would not work. I think I soaked and shorted the relay coil which might explain why there is less than one volt going to the relay.maybe it will dry out in a week???Try resoldering the relay and clean the relay contacts . I have used 600 or 1000 grit sandpaper soaked in deoxit. Pull thru the closed contacts a couple times .
Thanks. I do have a part number and source for the relay. I may buy it this weekendDo you have a part # for the relay?
Or can you read any of the specs.
If we can't find an exact replacement, we likely can find a suitable work around.
Also deoxit does dry . Once blown out, if you give it a day or so, it might come back to life.
One Volt does not sound right to me. you may have a supply problem to the relay. I would look for a diode and a voltage regulator and or transistor in the power circuit to the regulator. on the PV8 the relay voltage is part of the filament circuit, so I imagine 6 or 12 volts should be present. Possibly your relay has some markings on it as well, maybe its a 5 volt relay.
