Considering a mono setup and I have questions...
Discussion in 'McIntosh Audio' started by Flatwounds, Sep 11, 2017.
  1. Flatwounds
    Flatwounds AK Subscriber Subscriber
    545
    Nashville, TN.
    Greetings all!
    I have been happily enjoying my mc225 and 2100 biamp system but low and behold, an mc30/c8 combo popped up locally. I am considering it.
    Here are my questions;
    Can I connect stereo components (stereo reel to reel) to the preamp via y cable - Stereo male rca to male mono? How would the stereo channels play through the mono preamp and amp? Would they be summed,or one side only? I have never done this so I don't know.
    My plan would be to get a mono turntable and enjoy mono records but I do have some stereo components that I would like to connect and be able to use with a mono setup. Pardon my ignorance.
    Also, could I wire two speakers in parallel? + to + - to - ? Would this be better at the amp or from speaker to speaker? The speakers are 8 ohm and identical to each other They are old (1964) Jensen.
    I appreciate any advice you may have.
    Thanks!
  2. 62caddy
    8,540
    NEPA
    Outputs from the tape machine could be ruined if summed in that manner. The speakers can be run in parallel at the 4 ohm tap of the MC30, no problem there.
    Chances are the equipment is going to need work to bring it all up to snuff - possibly up to $1,000 for both units is not out of the question.
  3. kevzep
    You need to properly sum the outputs, you can do this with a couple of resistors, google passive output summing.
    When you sum outputs you can cause damage, and the way the two outputs interact with each other can produce some rather odd results.
    Also summing increases levels, which what the resistors are for as well as separating the two outputs electrically.
  4. Flatwounds
    545
    Nashville, TN.
    Thank you. I've got to put my thinking cap on.
  5. Flatwounds
    545
    Nashville, TN.
    So, it is possible. It just has to be done correctly, electrically to avoid damage. Am I understanding you correctly? Thanks for your advice.
  6. Flatwounds
    545
    Nashville, TN.
    Basically, I'm trying to decide if I can run in mono, if the price is right on these pieces, and then eventually get another mc30 and run in stereo. Kind of a long term project. Thanks everyone for your advice.
  7. 62caddy
    8,540
    NEPA
    Could always add the C8S to the C8 and an MC30 for a true late '50s stereo system. McIntosh made the C8S to help facilitate the transition to stereo without having to replace the C8 outright. Of course service/repair costs will be deeper still.
    Personally I think a C11 would be the better way to go which will not be much more after all's said and done - and will have better desirability than a pair of C8s.
    cduarte likes this.
  8. mhardy6647
    51,405
    C8 is a dandy piece with the EQ network flexibility needed for pre-RIAA era record (especially 78s) EQ standardization.
    The MC30 is a pretty decent amplifier, too.
    This was a Klipsch recommendation for a "sum to mono" line-level box to create a center channel for a "three channel" Klipsch speaker array for home hifi. (The OP can ignore the L and R channels, of course). Also not that this particular implementation has a level control to adjust the center channel to mate with the L & R.
    EDIT: I posted the speaker level rather than line level box by mistake, see the RANE box below.
    See also the famous Rane white paper (apparently updated) at:
    http://www.rane.com/note109.html
    Flatwounds likes this.
  9. Flatwounds
    545
    Nashville, TN.
  10. Flatwounds
    545
    Nashville, TN.
    Thank you!
  11. cduarte
    cduarte AK Subscriber Subscriber
    717
    CT
    I agree with this completely, I think the C11 works wonderfully with the mc30s, especially since I'm now running this setup... forgive the crappy cellphone pic
  12. Flatwounds
    545
    Nashville, TN.
    Im on the fence. Seller wants a grand which is a good deal.
  13. Flatwounds
    545
    Nashville, TN.
    Beautiful!
    cduarte likes this.
  14. 62caddy
    8,540
    NEPA
    Fair price if cosmetics are reasonably good but remember an MC30 will be a good $500 to restore, excluding tubes. I can't say for the C8 but I would think similar. If marginal cosmetics, I would probably pass.
  15. Flatwounds
    545
    Nashville, TN.
    The cosmetics are 9 out of 10. We agreed on a slightly lower price.
  16. 62caddy
    8,540
    NEPA
    Can't go wrong then.
    Welcome to the MC30 club. :beerchug:
    Flatwounds and cduarte like this.
  17. TSmith8605
    TSmith8605 Senile Member Subscriber
    724
    Sunnyvale, CA
    This Klipsch combining circuit is designed to combine "Speaker Outputs of Stereo Receiver or Amplifier" which is completely different than combining the L + R line-level outputs of a tuner or CD player. This circuit it not applicable to the OP's situation.
  18. mnmmt
    mnmmt AK Subscriber Subscriber
    97
    I believe the MX114 has a "center" or summed output which can be used to run mono.
  19. mhardy6647
    51,405
    Oops, I pasted the wrong one; good catch.
    I'll just refer him to the Rane doc, then.
  20. cduarte
    717
    CT
    thanks, the mc30s aren't perfect, they were however completely rebuilt right before I bought them with my choice of coupling caps. They're more than presentable enough.
